Street Killer - JeepForum.com
post #1 of 17 Old 01-18-2014, 07:08 PM Thread Starter
davidshain
2009 KK Liberty
Street Killer
So, I have beat ideas for my Liberty till I have no more. So, with a 2WD and no possible way to trade or sell it with my negative equity, here is my plan:
Since she is 2WD and terrible off road, Im going the sleek and mean route with staggered wheels and tires. Im not going to lower it, just keep its OEM height. Since she is black, Ill go with black staggered wheels like 18x9 rear with 255/45-18 and 18x7 or 8 front 2ith 235/50-18. They are the same height so the computer will not be confused. Now let me repeat, this Liberty is a 2WD! Suggestions?
davidshain is offline
post #2 of 17 Old 01-18-2014, 10:54 PM
AtTheHelm
Do a custom long travel setup
AtTheHelm is offline
post #3 of 17 Old 01-19-2014, 05:59 AM
Gageraid
2008 KK Liberty
Maybe you can do some cool paint schemes with plastidip. I've done a few things, but it can really help ya bring out your creativity and give the Jeep personality.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #4 of 17 Old 01-19-2014, 06:33 AM
badhare
bag it
badhare is offline
post #5 of 17 Old 01-19-2014, 08:23 AM
s2killa
2011 KK Liberty
Originally Posted by badhare View Post
bag it
yes!!!! This is a most deff do!!
Instagram-DHR_S2KILLAA
11 Liberty KK l Daystar 2" l Rock Crawler 15x8 3.75" l M/T Baja MTZ 31x10.50
s2killa is offline
post #6 of 17 Old 01-20-2014, 07:26 AM
LKWJEEPER
2009 KK Liberty
Just thinking outside the box here.. Any additional funds you'd spend.. Why not use it to pay down the jeep. Before you know it.. You'll be getting a 4wd Libby on trade in.
Sent from AutoGuide.com Free App
LKWJEEPER is offline
post #7 of 17 Old 01-20-2014, 09:02 AM
huntb
2008 KK Liberty
You need wider than 255 in the rear... I have 255's all around
huntb is offline
post #8 of 17 Old 01-20-2014, 10:16 AM
tommudd
2004 KJ Liberty
have to remember that even though two different size tires are the same height, installing them on different width wheels will change that height somewhat
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #9 of 17 Old 01-20-2014, 10:20 AM
tommudd
2004 KJ Liberty
All depends on size, for example a 255-70-16 has a tread width of 7.4 inches, a 255-45-18 has a tread width of 9.1 inches
Good bit of difference
MUDD'S MOTORSPORTS
tommudd is offline
post #10 of 17 Old 01-20-2014, 03:02 PM
huntb
2008 KK Liberty
What? I thought 255 was the tread width in mm (255mm = 10.04") where did you come up with those numbers Tom? Not saying I don't believe the guru but that goes against what I've learned about tire sizing
huntb is offline
post #11 of 17 Old 01-20-2014, 03:55 PM
tommudd
2004 KJ Liberty
In a perfect world possibly it may be that way but not in the real world. It can get very confusing, but....
The second number on a tire size refers to the aspect ratio: This is the ratio of its section height to its section width. The smaller the number, the shorter the sidewall and the wider the tire. In other words, a 50 series tire is shorter and wider than a 60, even though they both might be 255's or whatever size you are discussing . A 85 series tire will be very narrow compared to a 75 or 70 series and on down. So just for discussion sake, a 255-85 maybe 7 inch tread width, whereas a 255-45 maybe 9-9.5 inches
MUDD'S MOTORSPORTS
tommudd is offline
post #12 of 17 Old 01-21-2014, 08:28 AM
huntb
2008 KK Liberty
Hm... I'm not so sure I follow your logic. The first number is the section width, the second number is the sidewall height as a percentage. So for a 255/65 my understanding is that the section width is 255mm and the sidewall height is 65% of 255 or 165.75mm (255*0.65). I have 255/65R17 so my overall tire height would be twice the sidewall height plus a 17" rim (431.8mm) SO: 165.75+165.75+431.8=763.3mm or 30.05" (which is what the original height of the tire was before tread wear).
So I know you understand aspect ratio but I don't understand how you say "The smaller the number, the shorter the sidewall and the wider the tire." Where did you come up with this?
I guess the smaller the sidewall height the less it will bow out (which will change the overall section width) but that is the inverse of what you are saying.
huntb is offline
post #13 of 17 Old 01-21-2014, 08:59 AM
tjkj2002
2002 KJ Liberty
Section width is not tread width,2 totally different parts of the tire.
You can change section width by simply mounting the tires on wider or thinner rims.The advertised section width(say 255/70R16) is measured on a specific rim size in which they will list on the company's website(what rim sized used to measure).The wider the rim the bigger the section width gets and the shorter the tire gets.Mount on a narrow rim and the section width decreases and the tire get's taller.
tjkj2002 is offline
post #14 of 17 Old 01-21-2014, 12:45 PM
lfhoward
2008 KK Liberty
Tread width is different from section width. Check out this tire from Treadwright's website:
https://www.treadwright.com/p-34-245...den-a-t-e.aspx
This is a 245/75/R16 BFG-A/T ~like tire.
Tread Depth:
16/32”
Meas. Rim Width:
7”
Tread Width:
7.9”
Rim Width Range:
6.5-8”
Max Load:
3,042 lbs
Outer Diameter:
30.7”
Max PSI:
80 psi
Section Width:
9.8”
I think TireRack.com lists all the stats on their tires as well.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #15 of 17 Old 01-21-2014, 01:42 PM
tommudd
2004 KJ Liberty
May I suggest you go to Tire rack for example , pick a size tire say 255-70-16 and look at the tread width, section width etc, then also look at the specs for say a 255-75, 255-65, etc . You'll see more what we are trying to explain.
You would of really been confused back in the day, when we went from numbers like 8.25X15 to G78-15, ( same size tire) the old guys didn't want the new sizes since they were different and their car was suppose to have 8.25 not some letter Then the radials hit in which made it worse , then metric sizes
MUDD'S MOTORSPORTS
tommudd is offline
