Strange problem, need some opinions - Page 2 - JeepForum.com
post #16 of 30 Old 12-10-2013, 03:59 PM
Gageraid
2008 KK Liberty
Originally Posted by jrich58 View Post
hey all, i have a bit of an update....today I noticed that the "chugging" sound doesnt happen when cold and not up to temperature yet....does anyone know if the tps is possibly disabled during warm up? Is there anything else that it could be seeing as it only happens when warmed up?
It's not disabled during start up, but will be in "open loop" during a short time of the warm up. After the open loop stage, it enters "closed loop" and it will return to open loop during heavy throttle/full throttle periods of driving.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #17 of 30 Old 12-10-2013, 05:24 PM Thread Starter
jrich58
2008 KK Liberty
Just got home from work, this problem is really getting to me. No idea where to start, honestly I dont have the extra $$ to go to the dealer for 92 an hour diagnostic fee. Without a CEL i dont know what else to check...anyone ever have a similar issue, the best i can describe it would be a fluttering type noise at first throttle, goes away after 1500 rpm or os. Anyone have suggestions? PLease Help!!
jrich58 is offline
post #18 of 30 Old 12-10-2013, 06:10 PM
Gageraid
2008 KK Liberty
Try going full throttle 5 times and see if that changes anything.
OME lift
Gageraid is offline
post #19 of 30 Old 12-10-2013, 06:19 PM Thread Starter
jrich58
2008 KK Liberty
I can't tell if your being serious or not, lol?
jrich58 is offline
post #20 of 30 Old 12-10-2013, 06:44 PM
Gageraid
2008 KK Liberty
I'm being serious. I never went full throttle in my vehicle until recently. It greatly improved how it felt while driving under normal conditions. Give it a shot on a safe back road that you know well.
OME lift
Gageraid is offline
post #21 of 30 Old 12-10-2013, 11:51 PM
Gageraid
2008 KK Liberty
If it helps, in gear, my ScanGauge says the throttle position is 11. Now find someone local that can check yours.
OME lift
Gageraid is offline
post #22 of 30 Old 12-11-2013, 05:16 AM
rescue575
2011 KK Liberty
Now I have to ask, do you mean floor it from stopped position? How long are you "punching" it for? I can't say I've had the same issue as discussed, but especially with the blast of cold we have been gettin, it has been driving real rough.
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #23 of 30 Old 12-11-2013, 06:36 AM
Gageraid
2008 KK Liberty
Yes, floor it all the way 0-60. You don't have to be at a complete stop. Sometimes I just hold it down to the ground till 4th gear catches on.
Once again, please don't be an idiot, use caution, and only on a unoccupied road you are familiar with.
OME lift
Gageraid is offline
post #24 of 30 Old 12-11-2013, 03:21 PM Thread Starter
jrich58
2008 KK Liberty
Hey all, I'm hoping someone can look at their KK engine and help me out. I believe this sensor that is mounted to the engine is the map sensor, it's between the alt and water pump. Mine is held one by one bolt to the left and what appears to be a broken bolt/stud on the right side. Can anyone confirm this should have two bolts or is the right side supposed to be some type of stud to hold it there? If anyone is willing to help out a fellow jeeper that would be awesome.
jrich58 is offline
post #25 of 30 Old 12-11-2013, 09:08 PM
JeepLibertyKK
2012 KK Liberty
When it was checked for an exhaust leak, did they check the cats? A plugged up catalytic converter can do weird things.
JeepLibertyKK is offline
post #26 of 30 Old 12-12-2013, 07:39 AM Thread Starter
jrich58
2008 KK Liberty
Not sure if they checked the cat or not, I will have that done. I tried the floor it 5 times, but didn't seem to help at all. I am stumped about this sensor, I can move it in/out a bit where it looks like there should be a bolt (rh side)....if this is supposed to be a bolted down area, could this also cause a vacuum leak? I'm really hoping someone could check theirs to see if it should be a bolt....I would be super grateful!!! I don't know anyone local with a KK...
jrich58 is offline
post #27 of 30 Old 12-12-2013, 11:19 AM
Gageraid
2008 KK Liberty
When I cleaned my EGR valve a month or so ago, it seemed to make the Jeep run smoother. Some say it doesn't affect driveability, but it seemed to work for me. It'll take you less than 15 minutes.
OME lift
Gageraid is offline
post #28 of 30 Old 12-13-2013, 10:09 AM
JeepLibertyKK
2012 KK Liberty
If the issue is the catalytic converter, romping on the throttle won't clear out the problem if the cat is plugged up. Not sure if this is even the problem but worth a look... major loss of power if they get plugged up.
My wife usually takes the Jeep to work, including today, but will try to get you a picture later this afternoon if no one posts by then.
Okay, since no one posted, do any of these photo angles help at all?
IMG_20131213_193234_610.jpg   IMG_20131213_193249_148.jpg   IMG_20131213_195204_498.jpg   IMG_20131213_195212_550.jpg   IMG_20131213_195307_814.jpg
post #29 of 30 Old 12-14-2013, 08:47 AM Thread Starter
jrich58
2008 KK Liberty
That helps a lot, mine looks exactly like that so I guess I'm not missing a bolt. This problem is so strange, I also noticed some air bubbles recently in my coolant, but I don't small any sweet smells. Could I have a small leak and Thai is the chugging sound I'm hearing? Not to mention its -17 today with the windchill...brrrrrr
jrich58 is offline
post #30 of 30 Old 12-14-2013, 09:42 AM
Gageraid
2008 KK Liberty
I think at this point we need a video clip of what's going on.
OME lift
Gageraid is offline
