Strange problem, need some opinions - JeepForum.com
post #1 of 30 Old 11-22-2013, 06:22 PM Thread Starter
jrich58
2008 KK Liberty
Hey all. My 2008 kk with 68000 miles has been running pretty bad lately. It has a chugging sound at acceleration, just from 600-1500rpm...jeep feels like it just doesn't have the power overall though. Once the jeep starts moving more than a couple mph, it sounds normal. I have changed the plugs...used NGK stock coppers gapped to owner manual specs, new air filter, cleaned a little of the throttle body, didn't move the butterfly though. I have also had a fresh oil change. No cel and idles rock solid at 600 rpm. Also had it checked for an exhaust leak, said it was fine. Is there anything else I can look at before having satan diagnose for a crazy ridiculous hourly rate.
jrich58 is offline
post #2 of 30 Old 11-22-2013, 08:30 PM
Katmandu
Throttle Positioning Sensor.
Katmandu is offline
post #3 of 30 Old 11-22-2013, 08:39 PM Thread Starter
jrich58
2008 KK Liberty
According to rockauto.com, the kk doesn't have a tps. Can anyone confirm this?
jrich58 is offline
post #4 of 30 Old 11-24-2013, 08:45 AM Thread Starter
jrich58
2008 KK Liberty
anyone know if our KK's have this sensor? What is the sensor located right at the throttle body where the intake tube connects?
jrich58 is offline
post #5 of 30 Old 11-24-2013, 12:36 PM
lfhoward
2008 KK Liberty
I think it is part of the throttle body assembly and can't be changed out by itself. My Scangauge II reads the TPS so the KK does actually have one.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #6 of 30 Old 11-24-2013, 03:16 PM Thread Starter
jrich58
2008 KK Liberty
is there a way for me to test it, to make sure its faulty before buying a new new TB assy? I heard its a potentiometer style sensor, anyone know what the ohms resistance should be?
jrich58 is offline
post #7 of 30 Old 11-24-2013, 10:35 PM
Gageraid
2008 KK Liberty
Not sure of how much of a test it would be, but if you know someone with a scangauge and borrow it, you'd be able to see what the tps was showing.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #8 of 30 Old 12-09-2013, 11:14 AM Thread Starter
jrich58
2008 KK Liberty
Thanks guys. Would someone be able to help me out? Im looking for the resistance value (ohms) of the tps in our KK's. I'd like to try and test it before spending almost $200 on a new throttle body assembly. Anyone willing to help me out and check theirs with a meter and provide the results?
jrich58 is offline
post #9 of 30 Old 12-09-2013, 11:58 AM
Gageraid
2008 KK Liberty
The best I can help you with is providing tps reading from my ScanGauge.
OME lift
Gageraid is offline
post #10 of 30 Old 12-09-2013, 12:10 PM Thread Starter
jrich58
2008 KK Liberty
okay, thanks. What kind of numbers would that produce? Ohms?
I always appreciate your help Gage!!
jrich58 is offline
post #11 of 30 Old 12-09-2013, 05:17 PM Thread Starter
jrich58
2008 KK Liberty
hey all, i have a bit of an update....today I noticed that the "chugging" sound doesnt happen when cold and not up to temperature yet....does anyone know if the tps is possibly disabled during warm up? Is there anything else that it could be seeing as it only happens when warmed up?
jrich58 is offline
post #12 of 30 Old 12-09-2013, 07:28 PM
BillyP
You should be getting a check engine light and codes if the TPS is defective - DTC P0123 - Throttle Position Sensor 1 Circuit High or P0222 - Throttle Position Sensor 2 Circuit Low are active or stored.
BillyP is offline
post #13 of 30 Old 12-10-2013, 07:08 AM Thread Starter
jrich58
2008 KK Liberty
hhmmm, def no check engine lights....I re-installed my hypertech tuning last night and had no codes. Weird thing is, when It is really dark out, when shifting from first to second, I can see my headlights dim for a split second. could this all be alternator related? I have the auto tranny.....?
jrich58 is offline
post #14 of 30 Old 12-10-2013, 02:55 PM
Gageraid
2008 KK Liberty
I think everyone's KK has some sort of weird headlight issues. Mine will dim slightly if I put the windows up or down. No big deal.
OME lift
Gageraid is offline
post #15 of 30 Old 12-10-2013, 02:56 PM
Gageraid
2008 KK Liberty
I forgot to check, but I will post tonight around midnight.
It's just tell you a number, not in ohms.
OME lift
Gageraid is offline
