strange cable unidentified ??? please help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > strange cable unidentified ??? please help
WJ Tube Doors Now Available!*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*TJ 5.25" Speaker Adapters - NalinMFG
Unread 07-07-2014, 01:40 PM   #1
redadeath
2013 KK Liberty
i found this cable plug under my brand new 2012 liberty
can any body tell me please what is it used for
it is located behind the head lights "driver's " side
thanx every one
redadeath is offline   Reply With Quote
Unread 07-07-2014, 03:19 PM   #2
Drednot
do you have the fog light option?
if not, its most likely the wiring harness for that. look for one on the passenger side, too.
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote
Unread 07-07-2014, 06:37 PM   #3
redadeath
2013 KK Liberty
This is my headlights
http://www.autotrucktoys.com/liberty...-PRD30506.aspx
What foglight option u means
I looked at the passenger side but this is the only harness i found
Unread 07-08-2014, 09:30 AM   #4
josworth
2010 KK Liberty
That is the connector for a plunger that is installed in the round plastic cup in your picture. I believe it is a "hood ajar" sensor for the factory alarm or EVIC. I have the plunger, Ted15 who has a 2010 sport does not have it. He does not have EVIC either. I can't upload pictures right now, but can later if you need them.
josworth is offline   Reply With Quote
Unread 07-08-2014, 11:05 AM   #5
redadeath
2013 KK Liberty
Thank you for ur help but what is the round plastic plunger in the picture do u mean the battery black circle in the first picture
Can u upload pictures plz
Unread 07-08-2014, 12:57 PM   #6
josworth
2010 KK Liberty
It is a part that you do not have. The mounting cup is shown in your pictures (#2 and #3) in the top of the frame. There is a plunger that snaps into that spot and the wire plugs into it.
I will try to get to uploading a picture of the installed plunger, but cannot promise anything for a while.
Unread 07-08-2014, 01:00 PM   #7
redadeath
2013 KK Liberty
Sorry for my dump quistions and thank you for your help
What is mounting cups used for...?
Unread 07-08-2014, 04:57 PM   #8
josworth
2010 KK Liberty
No need to apologize. I'm sure English is not your first language.
I described the plastic part that holds a sensor. All Liberties have the spot for the sensor, just not all of them actually have it installed. So, the wire you are looking at goes to something that your Jeep is not equipped with.
Unread 07-08-2014, 05:10 PM   #9
redadeath
2013 KK Liberty
thank you for help
Unread 07-10-2014, 04:19 PM   #10
redadeath
2013 KK Liberty
update:-
tha cable is used for the remote piece that start the engine wireless and i donot have it in my car
thanx all for ur support
Unread 07-11-2014, 06:53 AM   #11
josworth
2010 KK Liberty
update:-
That "hood open" sensor may be part of the system, but it is NOT the remote for remote start.
Here are pictures of the "hood open" sensor I referred to.
Unread 07-11-2014, 09:38 AM   #12
redadeath
2013 KK Liberty
the same holding cup are used for the system engine start
Unread 07-11-2014, 09:43 AM   #13
josworth
2010 KK Liberty
Where is that documented. I have remote start. It is controlled by a computer module.
Unread 07-11-2014, 09:53 AM   #14
redadeath
2013 KK Liberty
i though that piece is remote start.... does it have anothe piece plugged in the hood itself
Unread 07-11-2014, 11:49 AM   #15
josworth
2010 KK Liberty
Yes, there is a round rubber bumper that contacts the plunger when the hood is closed. In addition, unplugging it for the pictures triggered a trouble code. I got code B1820 Hood Sensor circuit.
