Staggered tires. - JeepForum.com
post #1 of 1 Old 06-06-2011, 09:02 PM Thread Starter
1VG
Staggered tires.
I'm thinking about getting some staggered tires (wider at rear) for my KK.
At full throttle from a stop the rear tires break traction and the traction control kicks in. I'd like a bit more grip at the rear, enough to put down the modest V6 power without any fuss. I've raised the tire pressures and although it is an improvement, I'd like more traction at the rear.
From what I've read larger tires without a lift will rub when flexing and the fronts will rub at full lock. The most the suspension on my Jeep will flex is when I floor it from a stop, at full braking, and at full cornering on pavement. To avoid rubbing when turning I'd like to keep the fronts close to stock.
I want road tires with lots of traction on pavement. They will never see mud, dirt, rocks, ice, or snow. Maybe some occasional rain on pavement, but that's it.
I don't want to lift my KK because that would raise the center of gravity (and it will never be off the road anyway so I don't need the clearance).
I know I won't be able to rotate (only left to right), that's not a problem. I'm used to cars that came staggered from the factory so that's nothing new.
My KK came with 235/70R16 stock. I'd like to use the same wheels.
My first option: BF Goodrich Long Trail T/A Tour. I've had great experiences with BF Goodrich on road cars.
235/70R16 Front (Same as OEM) [Radius: 367.7mm]
255/65R16 Rear [Radius: 369mm]
The front tires are the same size as the originals, and the rears are within 0.3% of the original outside diameter. This would avoid problems recalibrating the speedometer and the gearing would be kept the same.
My second option: Continental ContiCrossContact LX. I have no references good or bad for this tire.
245/75R16 Front [Radius: 387mm]
265/70R16 Rear [Radius: 388.7mm]
These are wider tires, but also taller. I'm not particularly interested in a taller Jeep. The difference in outer diameter between these two tires is 0.5%. However, they are 5.7% taller than stock, so the speedometer would need recalibration and the gearing would be affected as well as the center of gravity raised. Although they are rated to fit on a 7" wheel, 265s on the stock wheels might look odd.
In this thread (http://www.jeepforum.com/forum/f292/...-size-1071276/) doejake (barely) fit 265/65R17 on a stock KK. [Radius: 388.2mm] The 265/70R16 should be 0.5mm larger than what doejake fit.
I'm thinking that the 255s should work for what I'm looking for (more traction at the rear) without any of the problems and uncertainty of the taller 265s (as well as added weight). I'd like to keep my tires close to the price range of these two, about $160 per tire.
What do you guys think?
1VG is offline
Thinking about new tires for th KK JACKTV KK Liberty Forum 9 02-22-2011 10:20 PM
Free tires! Gfox33 KK Liberty Forum 4 01-27-2011 07:58 PM
Wheels and Tires RB145 KK Liberty Forum 4 08-14-2010 12:40 PM
Want to see pics of after market Tires matt1u2 KK Liberty Forum 2 03-24-2010 06:47 PM
Looking for Stock Wheels and Tires erjennin KK Liberty Forum 3 03-13-2010 09:26 PM
