Spark Plugs Change 2008 Liberty Limited 3.7 - JeepForum.com
post #1 of 10 Old 11-18-2010, 05:35 PM Thread Starter
Rambler1
2008 KK Liberty
Need help trying to locate the spark plugs? Is there individual coils on every plug? How do I go about changing the plugs myself, not completely inexperienced. But I am having a difficult time locating the plugs. Also which type plugs do you guys use. Engine 3.7 with auto trans and towing 5000 lbs. Is there any graphic to look at.
If anyone has any tips / suggestions to make this job easier please let me know.
Thanks In Advance
Rambler1
Delaware
Rambler1 is offline
post #2 of 10 Old 11-18-2010, 08:02 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Yup there under the coil pack. Check out http://www.jeepforum.com/forum/f28/change-spark-plugs-02-07-jeep-liberty-kj-1106657/ It looks a little different but is the same engine. Make sure you blow all the dirt and dust off around the spark plug and coil pack because if dirt falls in the socket hole it goes directly into your engine. The factory sparks are pretty darn tight in there. There all easy except the rear pass side one, youll need a universal elbow to get the socket in there. Plugs i put in are the originals that came with it. http://www.amazon.com/gp/product/B000GZGV3E/ref=oss_product. Theres no point in putting those so called high performance plugs since the engine will not benefit from them, just my opinion. Just put in NGK ZFR6F-11G 6987 Plugs.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 10 Old 11-19-2010, 11:44 AM
enrico1
2008 KK Liberty
what do you think about the NGK ZFR6FIX-11 6411 IRIDIUM 1X PLUGS.?
I LOVE MY JEEP
enrico1 is offline
post #4 of 10 Old 11-19-2010, 02:21 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
I would just stick with the ones that came with the engine.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 10 Old 11-20-2010, 06:29 AM
VMF
2008 KK Liberty
what he said i also went with the original ones, no point in wasting money on high performance ones. and imho u want ur car reliable, not fast, especially when it comes to jeeps
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #6 of 10 Old 11-20-2010, 03:26 PM
SuperRliBerty
2008 KK Liberty
ELT, In that video, the battery was not disconnected, I always disconnect the battery before do any electrical maintenance on a vehicle.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #7 of 10 Old 11-21-2010, 08:05 AM
VMF
2008 KK Liberty
no need to disconnect the battery as long as u dont keep the ignition on or dont start the car it should b ok when it comes to changing spark plugs. disconnecting the battery will erase all the ECU data about ur drving and put it into learning mode.
2004 UCF31. Black
VMF is offline
post #8 of 10 Old 04-24-2011, 06:51 PM
seahawk190
2009 Spark Plug Replace question
seahawk190 is offline
post #9 of 10 Old 04-25-2011, 06:43 PM
SuperRliBerty
2008 KK Liberty
At each oil change or any electrical work on my j-lib, I disconnect the battery with my installed battery quick disconnect.
I have NO ELECTRICAL GLITCHES, NO COOLING PROBLEM AND NO IDLING ISSUES!
2008 Sport Liberty
post #10 of 10 Old 04-26-2011, 07:08 PM
jsburton84
2008 KK Liberty
I just changed my plugs today for the $2.99 auto-lite platinum plugs from auto zone. Nothing fancy, just regular single electrode. The engine starts and idles much smoother and quieter now. I think someone else on here recommended those before. I am definitely liking the improvement.
2008 KK sport 4x4
1998 XJ sport 4x4 (sold)
jsburton84 is offline
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 06:02 PM
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 11:31 AM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 08:09 AM
Spark plugs every 30k? KUHawkhead KK Liberty Forum 32 09-13-2010 07:19 PM
Correct Spark Plugs?? Elt31987 KK Liberty Forum 0 03-23-2010 08:26 AM
