Spare tire - JeepForum.com
post #1 of 11 Old 03-15-2011, 07:43 PM Thread Starter
KKevin
2011 KK Liberty
Spare tire
My 2011 KK Limited came with a donut rather than a full size spare tire. I plan to replace it with a full size. I was just wondering, will I have to replace the winch or any of the mounting hardware?
KKevin is offline
post #2 of 11 Old 03-15-2011, 07:48 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Nope, pretty sure you can get another stock KK rim and the center will come out and allow you to mount it right up.
from local MA Jeeper
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 11 Old 03-16-2011, 10:27 AM
VMF
2008 KK Liberty
weird, i thought full spare is part of the deal for the limited.
i have full spare. inquire with the dealer as to why urs came without it
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #4 of 11 Old 03-16-2011, 07:32 PM Thread Starter
KKevin
2011 KK Liberty
I assumed that it was too. this is my 3rd jeep (not including company cars that I had when I worked for Chrysler Financial) and all had full size spares.
I checked my sticker; no mention of it. I then went on the Jeep website and it turns out that a full size spare is optional equipment.
Thanks to both of you above for your input.
KKevin is offline
post #5 of 11 Old 03-17-2011, 03:07 PM
SuperRliBerty
2008 KK Liberty
With a fullsize tire as a spare, the TPMS ( tire pressure monitoring system) will still illuminate the "tire pressure lo" light.
The liberty "donut" spare tire is not TPMS monitored.
If you see this TPMS icon illuminated, it means your vehicle has a low tire. STOP, and check the inflation pressure in your tires. This warning light will come on if tire pressure in any of your tires falls more than 25% below the recommended inflation pressure (refer to your owners manual, or the tire inflation decal in the glovebox, driver door pillar or gas tank filler cap lid for tire inflation pressure recommendations).
The TPMS warning light should come on for about one second when the ignition key is first turned on for a bulb check. It should then go out if all of the tires are properly inflated. If it does not go out, or it comes on while driving, you have a low tire.
NOTE: If the TPMS warning light is flashing, it indicates a fault has been detected in the TPMS system that will require further diagnosis. Common faults include a bad tire pressure sensor, a defective keyless entry receiver module, a fault in the TPMS or body control module (BCM), or wiring problems in the keyless entry/TPMS/BCM circuit.
TIRE PRESSURE MONITOR SYSTEMS
This brings us to tire inflation monitoring systems. If motorists won't check their tires, vehicles can be equipped with their own tire pressure monitoring systems (TPMS). For model year 2008 and beyond, National Highway Traffic Safety Administration (NHTSA) regulations require all new cars and light trucks to be equipped with a tire pressure monitoring system. The TPMS system must warn the driver if the pressure inside any tire on the vehicle is 25 percent or more under the recommended inflation pressure.
Many late model cars and SUVs are factory-equipped with TPMS. Run-flat tires with a TPMS system have been used since 1989 on the Chevrolet Corvette. Other older run-flat/TPMS applications include the Plymouth Prowler, BMW Z8, Mercedes-Benz SL55 AMG, 2002 Infinity Q45 and 2004 all-wheel drive Toyota Sienna.
TPMS can also be found on the following vehicles that have conventional tires: 2003 Ford Explorer, Mountaineer, and Lincoln Navigator, 2000 Cadillac Seville & DeVille, 2003 Chrysler 300M, Town & Country minivan and Dodge Viper, and Jeep Grand Cherokee and Liberty. Import applications include 2001 and up Audi A8 and Quattro, 2001 and up BMW M3, 2003 and up BMW 3-Series, &-series and Z4 roadster, 2000 and up Nissan Quest minivan, 2003 and up Nissan 350Z and Murano SUV, and 2004 Toyota Sienna. For model year 2008 and newer vehicles, all passenger cars and light trucks that are sold in the U.S. must be equipped with TPMS.
DIRECT & INDIRECT TIRE PRESSURE MONITORS
There are essentially two basic ways to monitor tire pressure electronically. One is the direct method. A small pressure sensor is located inside each wheel. The sensor has a built-in transponder that broadcasts a radio signal to an external module. The module identifies the signal from each wheel and keeps an eye on pressure. If pressure drops below a predetermined threshold, the module turns on a light or displays a message to warn the driver.
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
post #6 of 11 Old 03-17-2011, 03:15 PM
VMF
2008 KK Liberty
limited has an EVIC so it shows you exact pressure in every tire minus the spare. no need to manually check it
2004 UCF31. Black
VMF is offline
post #7 of 11 Old 03-17-2011, 03:25 PM
SuperRliBerty
2008 KK Liberty
The Sport has the light only
2008 Sport Liberty
post #8 of 11 Old 03-23-2011, 12:38 PM
Korruptor
I didn't know that the TPMS would go off even if the spare was under inflated. maybe that's what was happening last summer. Sometimes it would go off but all my driving wheels were aired up appropriately... I'll have to check the spare.
As for the spare, my 2008 Sport build list has nothing on it for a full size spare, but I do, in fact as confirmed visually, have a full size spare.
"THIS is my BOOMSTICK! You can find it in Aisle 5 of the sporting goods department... Shop Smart, Shop S-Mart!"
Korruptor is offline
post #9 of 11 Old 03-23-2011, 12:53 PM
sloan74
Mine came with a full spare. It's not a Limited though. It has the tow package. I think it comes with the "Trailer Tow Class III Group".
sloan74 is offline
post #10 of 11 Old 03-23-2011, 01:00 PM
SCT100
2010 KK Liberty
Or the Preferred Equipment package. The one I drive has a full-size, with the 235-size tires.
The other one has the 225 tires, and has a donut as a spare (60psi, by the way).
SCT100 is offline
post #11 of 11 Old 03-23-2011, 01:07 PM
Korruptor
Ahhh, I do have the "Trailer Tow Class III Group". Maybe that's it.
KK Max tire size DaveV KK Liberty Forum 46 06-28-2014 07:17 AM
Spare jacked in the night...what kind of cable will I need? HeadshotSK KK Liberty Forum 6 07-26-2010 03:10 PM
2008 KK Spare Tire TPMS jscotts KK Liberty Forum 4 07-12-2010 07:37 PM
Accessing a 2010 Liberty spare tire. pauld73 KK Liberty Forum 9 06-25-2010 05:25 PM
Spare tire question on the KK 09_Silver KK Liberty Forum 4 12-17-2009 12:22 AM
