Smoke Burnt Rubber Smell from Brake? - JeepForum.com
post #1 of 5 Old 08-03-2014, 02:43 PM Thread Starter
mai-ling
2008 KK Liberty
Just got home from concerting and an errand
to feel the car acting weird and when I got out
I smelled that burnt rubber smell and smoke from
my front passenger tire.
This happened to my husband's Ford F-350,
same side. Took the tire off and rust came out.
I'm waiting for mine to cool down before I touch it.
But the rotor looks fine from the outside.
I'm guessing rusty stuff got in it? Like it did with
my husband's truck. We had a pretty hard rain the
other night I hadn't driven it since Friday.
Why Why Why does that happen?
The rotors and pads were put on August last year.
I've only put on maybe 3k miles if not even.
I am sure with all the construction stuff gets in
the wells from the construction that is going on.
you will remember my name
World's Youngest Illusionista | 7th greatest pianist in the world | Go Red For Women and Stroke Ambassador
www.mai-ling.net
mai-ling is offline
post #2 of 5 Old 08-03-2014, 05:24 PM
josworth
2010 KK Liberty
Dirt and crud won't really do that. If the Jeep was driving weird, do you mean it felt... sluggish? My guess is that the caliper is dragging for some reason. If so, that would create enough drag to effect drive ability. Remember, despite what the press told you during the "Toyota Incident", your vehicle's brakes are strong enough to stop the vehicle even under full load acceleration. So, I would get that wheel off right away and go over those brakes real good before driving it again. The "rusty" stuff in the rim could very well be burnt brake material.
josworth is offline
post #3 of 5 Old 08-03-2014, 05:30 PM Thread Starter
mai-ling
2008 KK Liberty
We just got back in from taking the tire off and rotating the rotor around. It moved freely.
There has been so much construction, rain and I was on gravel road the other day. Dust
and stuff may have gotten up there. So we cleaned everything off and looked at the other
tires. The other Driver side rims were quite dirty. So who knows. I took it out for a car wash
and then check it and it seems fine. Then drove off to home going really fast. When I got
home I checked again and no smell, no smoke and clean.
When this happened to my husband there was a rock stuck in his. Since then he hasn't had
any issues.
So hopefully I won't either.
www.mai-ling.net
mai-ling is offline
post #4 of 5 Old 08-03-2014, 05:43 PM
josworth
2010 KK Liberty
Good, you got lucky..
When you have time, I would still check the pads on both sides. Make sure they are the same thickness and all. Also make sure they are moving freely in the guides. Pads float, meaning that a rock could have gotten lodged in the grove when braking and locked the pad up. Trust me when I say I really think the smoke and smell you got was a roasting pad..
josworth is offline
post #5 of 5 Old 08-03-2014, 05:49 PM Thread Starter
mai-ling
2008 KK Liberty
Yeah the thickness were the same and it didn't chew up the pads or the rotors. Your right, roasting for sure on a hot day.
www.mai-ling.net
mai-ling is offline
