SkyJack 2.5" Lift kit - JeepForum.com
post #1 of 7 Old 12-02-2013, 07:36 PM Thread Starter
Tuxster
I was thinking of what a 2.5" lift would look like on my 2009 Liberty limited. Any one have a few pictures?
The kit is complete with struts, coils and shocks to give the jeep a 2.5" lift but its not cheap. I found a local dealer who sells the kit for $900.
Looking to see if the juice worth the squeeze.
Thx
Tuxster is offline
post #2 of 7 Old 12-02-2013, 08:11 PM
Stang977
Stang977's Avatar
2012 KK Liberty
As I just ordered a 3.5" Econolift from Jeepinbyal.com I'll give it a try:
Skyjack= No!
Skyjack springs rated same as stock 310 lbs, will sag soon enough after install.
OME lift much better:
http://http://jeepinbyal.com/jeep-li...ft-kit-kk.html
You should get 2.5" with the 927 and 721 springs. N132L shocks are necessary in the rear. Al's A arms are recommended if you can swing it.
BTW. 245-75-16's the recommended size without a regear.
EDIT: I see you noticed the lift from musclez. That's a great deal right there!
Don't worry, others will be checking in. Please consider equipment from Marlon at JBA. Proven over and over to be the best for our Liberty's. Many choices there.
Me- 2012 KK, Latitude, Mineral Grey, "Cherokee" Moulding,
JBA Tommudd 3 1/2" Econolift
265/70R16 Nitto Terra's
Fuel Revolver 16X8
Rock Lizard Basket Rack/ 40" Rigid Lightbar
Her- 2011 WK2 Laredo X, Brilliant Black
Stang977 is offline
post #3 of 7 Old 12-03-2013, 04:35 AM Thread Starter
Tuxster
After looking at some pictures of the lift installed, I am not sure it's what I'm after. I like the liberty for the retractable roof but as a daily driver it's kinda gutless and really sucks gas. With the lift and maybe new tires and rims would make me want to appreciate it more but I'm no so sure.
Tuxster is offline
post #4 of 7 Old 12-03-2013, 06:12 AM
Stang977
Stang977's Avatar
2012 KK Liberty
Having a 09', you are in luck. Hypertec makes a chip for you.
http://www.jeepforum.com/forum/f292/...3-7-a-1327990/
Some on here have it and like it. Unfortunately, they haven't made one for 2010'-12' yet.
I was in the same boat as you. Lift or not to lift. Even though it will be a bit of a dog I decided that as much as I like it now, I'll really like it after the lift. The front kinda rides like a brick now and the spring change out will be a vast improvement.
Fuel Revolver 16X8
Stang977 is offline
post #5 of 7 Old 12-03-2013, 02:15 PM
priebe
2008 KK Liberty
I ended up getting the 250k Kit from Skyjacker and it did sag a bit after a couple thousand miles. I put on a set of JBA ” clevis spacers in the front to level it back out. It looks just about right now. I have a set of JBA strut spring spacers that may end up going in over the summer. All of which are just band aids for now. Since the kit came with Nitro shocks I might just swap in a set of JBA springs at some point in the future? I am also running 245/75/R16 Duratracs with a cat back Dynomax exhaust and the Hypertech tuner. I am happy so far, but this thing is still pretty gutless and I could not imagine living above sea level or towing anything, geezzz.
priebe is offline
post #6 of 7 Old 12-03-2013, 07:20 PM
tommudd
2004 KJ Liberty
Have to replace the springs and shocks both since the Skyjacker shocks are different than others. Installing the clevis etc is a poor bandaid fix and the ride will be getting worse and worse.
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #7 of 7 Old 12-03-2013, 07:23 PM
Bmxer524
2011 KK Liberty
That's 3.5" on 245/75-16s(31s). Sure there's a power loss, but it isn't too bad. It kicks down a bit more in the mountains. Mpg dropped a bit, I'm averaging 14-15 instead of the 16-17 I was getting. It's a OME/Bilstein lift. 927 front springs, 731 rear springs, bilstein shocks, 1/4" top plate, 3/8" clevis, and 2 extra rear isolators. Also al's a-arms are pretty much a must at this height. Rides great on and offroad.
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
