Hello,
My father purchased a 2008 Liberty Limited this past October. It has the factory Infinity stereo with touchscreen head unit (navigation, hard drive, Sirius).
The Sirius radio has been inconsistent re locking onto the signal. It will sometimes be fine, and other times cut out a lot, taking varying degrees of time for recovery. The Mercedes my mother has doesn't not give anywhere near the amount of trouble coming from the Jeep in this regard.
We found the antenna had very deteriorated outer coating, and replaced the antenna. This helped a bit, though is not anywhere near correct. After contacting Sirius, they advised the satellite radio module is likely not working correctly.
Any thoughts re this? If the module does sound like it could be the problem, what is the proper name for this, and the model #? Where is the part mounted within the vehicle?
Thank you in advance...
