Roof Rack Side Rails - JeepForum.com
post #1 of 10 Old 01-13-2012, 06:51 PM Thread Starter
yj413
2011 JK Wrangler
Hello, spend most of my time over on JK side of the forum but I have a question about the Liberty KK. My wife drives a 2011 KK that didnt come with any roof rails on it, just some molding piece. Is it possible to by the rails and mount em. i have been googling for a while now and am about to give up as I cant find anything. I am only used to buying stuff for my wranglers.
thanks
yj413 is offline
post #2 of 10 Old 01-13-2012, 08:15 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Just found this:
http://www.rocky-road.com/kjrails.html
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 10 Old 01-14-2012, 04:31 AM
Czettwoch
Yes, if it is the same set-up as an 2008. my wife has a 2008 that had just the plastic trim pieces as well. I purchased the oem rails and installed them. I warn you it is a little pain, as the plastic trim is bolted and glued down a well. Just be careful and take your time so you don't damage any paint. It will take some time and goof off works great to remove the adhesive from the glue. The plastic trim will probably break as you remove it.
Czettwoch is offline
post #4 of 10 Old 01-14-2012, 08:37 AM
bagwell
2011 KK Liberty
Originally Posted by jeepn4kc View Post
$180!?!??!?
how much were the OEM rails? and where did you get them?
bagwell is offline
post #5 of 10 Old 01-14-2012, 09:35 AM
jonrjen
2011 KK Liberty
Keep in mind that if you plan to use the rails for other than looks, you will need to purchase the cross bars also.
If you want to go OEM I would look at a pair from a local wrecking yard and recycle the parts and some of your money.
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #6 of 10 Old 01-14-2012, 07:34 PM
45williams
2008 KK Liberty
I was wondering how is the fit with the rocky road rails? I heard they don't mount up flat and there is a gap.
45williams is offline
post #7 of 10 Old 01-15-2012, 12:28 PM
huntb
2008 KK Liberty
There was a little gap on mine but its easy enough to bend them so they fit flush. Plus they look so much better than stock rails
huntb is offline
post #8 of 10 Old 01-15-2012, 08:32 PM
JeepN4KC
JeepN4KC's Avatar
Those RRO rails for the KK are steel tubes, no? Pretty stout?
~Mike~
WK
XJ
JeepN4KC is offline
post #9 of 10 Old 01-16-2012, 07:29 AM
huntb
2008 KK Liberty
Yeah they are extremely rugged. Only issue is if the powder coat gets chipped (which it will) they will rust. I'm thinking about sanding them down and giving them a couple of coats of matte black rustoleum
huntb is offline
post #10 of 10 Old 01-16-2012, 08:57 AM
musclezmarinara
2012 KK Liberty
I used the thule cross rails
2012 KK Cherokee * Arctic * Mineral Gray
- Mods - See Build Thread..
musclezmarinara is offline
Rocky roof rails install?? stubble88 KK Liberty Forum 20 04-26-2015 06:00 PM
Roof Rails on KK with Sky Slide 3believers KK Liberty Forum 17 12-12-2011 02:22 PM
Roof rails build?? Anderson75 KK Liberty Forum 0 08-17-2011 10:59 AM
roof rails MiKESrEd94 KK Liberty Forum 2 08-09-2011 11:47 PM
Opinions on best roof rails and trailer hitch Lafaso870 KK Liberty Forum 3 10-18-2010 11:37 AM
