Roof mounting lights - JeepForum.com
post #1 of 15 Old 06-02-2014, 03:50 AM Thread Starter
Halloween
I am in the process of mounting lights to my roof rack and was wondering how most of you went about running the wires? Is there a drain whole under the rail mounts I could access
I want to keep the wiring as low key hidden and factory looking as possible and not have wires everywhere c
Thanks
Halloween is offline
post #2 of 15 Old 06-05-2014, 11:08 PM
RMarine
2008 KK Liberty
I actually ran mine to the back upper inside of the rear lid. cut a small hole in the rubber wire grommet already there then siliconed it. Considering I live in Seattle Wa, I can tell you no leeks from it :P
RMarine is offline
post #3 of 15 Old 07-16-2014, 12:28 PM
Arctic_4x4
2012 KK Liberty
I used the Mopar kit. It's easy to install, you just have to summon the nerve to drill a hole in your roof.
Arctic_4x4 is offline
post #4 of 15 Old 07-16-2014, 02:04 PM Thread Starter
Halloween
That's the issue. I know I have to but want to do it in the most covert kind of way
post #5 of 15 Old 07-16-2014, 02:45 PM
Arctic_4x4
2012 KK Liberty
It was hard drilling into a new car but the instructions were good and as long as you take your time with the measuring and drilling, there are no problems. I've had it for a year now and it has survived numerous rain storms and winter with no leaks at all.
post #6 of 15 Old 07-16-2014, 02:48 PM
RENE65
2008 KK Liberty
Measure twice, drill once
RENE65 is offline
post #7 of 15 Old 07-16-2014, 02:54 PM
Arctic_4x4
2012 KK Liberty
I think I measured 20 times before the smallest drill bit I had made the first hole
post #8 of 15 Old 07-16-2014, 04:37 PM
badhare
Best way to do it, personally.
Then again, i don't have the balls to drill a hole in the roof.
All the rest of you must have some serious nuts. ;p
badhare is offline
post #9 of 15 Old 07-23-2014, 02:38 PM
Mattyvac
2012 KK Liberty
My lights were LED, so I only needed 14ga wire. I ran mine under the weather striping and down the side of the windshield into the engine bay where by fuse box is.
Mattyvac is offline
post #10 of 15 Old 07-23-2014, 05:51 PM Thread Starter
Halloween
Photo ?
post #11 of 15 Old 07-23-2014, 06:40 PM
Mattyvac
2012 KK Liberty
Here's the best photo I have, and I added some MSpaint to it lol
The red line is where I ran the wires + and - under the weather stripping and the roof rail, the yellow circles are where you can kind of see my two black wires sticking out to verify that path.
Mattyvac is offline
post #12 of 15 Old 07-24-2014, 10:12 AM
rescue575
2011 KK Liberty
Here's the best photo I have, and I added some MSpaint to it lol The red line is where I ran the wires + and - under the weather stripping and the roof rail, the yellow circles are where you can kind of see my two black wires sticking out to verify that path.
hey Matt,
How did you get the wire under that plastic rail between the roof rail and windshield?
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #13 of 15 Old 07-24-2014, 10:49 AM
Mattyvac
2012 KK Liberty
Originally Posted by rescue575 View Post
hey Matt,
It's held in with clips, use a flathead screwdriver to get under it and pop it up or pry it over- once you have a gap just run your wires in there.
I put a little hot glue every few inches to keep my wires down in the groove.
Mattyvac is offline
post #14 of 15 Old 07-24-2014, 04:25 PM
rescue575
2011 KK Liberty
It's held in with clips, use a flathead screwdriver to get under it and pop it up or pry it over- once you have a gap just run your wires in there. I put a little hot glue every few inches to keep my wires down in the groove.
Great. Gotta give that a try this weekend. Was the glue absolutely needed or did you just do that for your own peace of mind?
2011 Liberty Sport
post #15 of 15 Old 07-25-2014, 09:44 AM
Mattyvac
2012 KK Liberty
Not needed I don't think. Depends on how rigid your wires are I guess.
Mattyvac is offline
