Replacing '09 Rear Brakes - JeepForum.com
post #1 of 15 Old 10-05-2012, 07:21 PM Thread Starter
cotterkp
2009 KK Liberty
Has anyone done the rear brakes on an '09 Liberty? I am wondering what kind of pistons the brakes have, are they the simple type that just push back in or the type that need to be spun and require the special tool?
cotterkp is offline
post #2 of 15 Old 10-06-2012, 06:57 AM
MikeDomme
I have done the rears of an 08 and they were simple. no special tools.
MikeDomme is offline
post #3 of 15 Old 10-08-2012, 12:20 AM
mjcougler
2015 WK
Here are the problems I had. Read carefully:
http://www.jeepforum.com/forum/f292/...otors-1305505/
Good luck,
Mike Cougler
15 Jeep GCL; 11 Jeep CL; 67 Jeep M725 Ambulance;
04 Ram 2500 CTD; 46 Willys CJ2A
mjcougler is offline
post #4 of 15 Old 10-09-2012, 11:32 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Should be a simple piston you can use a c-clamp to compress. Jack it up, break down the rears and find out - wouldn't take but a couple minutes.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #5 of 15 Old 10-11-2012, 02:00 PM
DrYJ92
You got a better response to your thread then I did. I just did my wife's 09 and like others have said simple piston caliper easy to change the pads. No special tools just a c-clamp.
On another note anyone know how to adjust the parking brake? I can't seem to locate a cable tension adjustment like my YJ has. Thanks.
DrYJ92 is offline
post #6 of 15 Old 08-10-2013, 08:34 PM
medinapool
2010 KK Liberty
I just tried to do my 2010 Liberty. The issue with my rear rotor replacement was the emergency brakes wouldnt release so i couldnt get the rotors off. I use my emergency brake once or twice a year just so they dont seize up. The issue is the inside of the rotors is about 3 inches deep. The emergency brake pads are only 2 inches wide and set inside the rotors. This leaves one inch of nothing but corrosion and traps the pads. I tried turning the adjuster from the back side (remove rubber graumet) but my adjuster wouldnt budge. This is a poor design. I beat on the rotor for 2 plus hours and had a giant gear puller. I heard the trick is taking it to a shop with a frame lift were your can put car in neutral and spin back axel as you hammer on rotors. I have done hundreds of brakes and this is the first one that i gave up on.
medinapool is offline
post #7 of 15 Old 08-10-2013, 08:53 PM
myfirstjeep1
Junior Member
This is what happened to me. Brought it to ashop and they had it done in minutes.
myfirstjeep1 is offline
post #8 of 15 Old 08-11-2013, 11:22 PM
JeepN4KC
JeepN4KC's Avatar
Should be an adjustment dial/star/wheel (whatever you wanna call it) behind the drum portion of the rear rotor - driverside IIRC.
~Mike~
WK
XJ
JeepN4KC is offline
post #9 of 15 Old 08-12-2013, 08:12 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
from the 2009 KK Factory Service Manual:
05 - Brakes/05 - Brakes, Base/Parking Brake/Adjustments
ADJUSTMENTS
NOTE: The parking brake is self-adjusting, it can not be adjusted.
Additional info:
1. Remove the center floor console (Refer to 23 - Body/Interior/CONSOLE, Floor - Removal) .
2. With lever in DOWN position, pull up on the core cable (4) rotating the drum (5) until the drum cut-out aligns with hole on lever tab (3), then install a punch (2) in this hole and drum cut-out. Release grasp on core cable.
3. The park brake system is now locked out to perform necessary repairs.
JeepCares is online now
post #10 of 15 Old 08-17-2013, 06:49 PM
medinapool
2010 KK Liberty
emergency brake adjuster
on a 2010 if you want to adjust emergency brake you maybe best off to remove the drum/rear rotor. You can then easily see the adjuster for that emergency brake. You can also on the back side of the wheel hub is a rubber graumet. Remove it and shine a light inside the hole. you will see the adjuster. I dont know if tightening is a good idea. You need to loosen it to remove the rotor. You would need to do both sides. These should be self adjusting and not done manually, i would think.
post #11 of 15 Old 08-17-2013, 10:35 PM
AtTheHelm
REAR DRUM IN HAT PARK BRAKE (ROTOR INSTALLED) USING ADJUSTING TOOL
Adjustment can be made with a standard brake gauge or with adjusting tool . Adjustment is performed with the complete brake assembly installed on the backing plate.
1. Be sure parking brake lever is fully released.
2. Raise vehicle so rear wheels can be rotated freely.
3. Remove plug from each access hole in brake support plates.
4. Insert adjusting tool through support plate access hole and engage tool in teeth of adjusting screw star wheel .
5. Rotate adjuster screw star wheel (move tool handle upward) until slight drag can be felt when wheel is rotated.
6. Push and hold adjuster lever away from star wheel with thin screwdriver.
7. Back off adjuster screw star wheel until brake drag is eliminated.
8. Repeat adjustment at opposite wheel. Be sure adjustment is equal at both wheels.
9. Install support plate access hole plugs.
10. Lower vehicle.
11. Apply park brake hand lever and make sure park brakes hold the vehicle stationary.
12. Release park brake hand lever.
AtTheHelm is offline
post #12 of 15 Old 08-18-2013, 09:26 PM
shawnicles
shawnicles is offline
post #13 of 15 Old 08-18-2013, 09:53 PM
MtBJet
Powerstop makes great rotors. EBC makes great pads... Not sure about their rotors.
MtBJet is offline
post #14 of 15 Old 10-21-2013, 05:53 PM
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Older thread, but I always thought you often have to release the parking brake cable tension in order to get enough parking pad clearance to remove the rear rotors.
Current: 2011 Grand Cherokee Overland V8, 2009 Liberty Rocky Mt V6
Previous: 2000 Grand Cherokee Laredo I6, 1979 CJ7 I6 Quadratrac
ColdCase is online now
post #15 of 15 Old 10-30-2013, 10:48 AM
JeepN4KC
JeepN4KC's Avatar
Originally Posted by ColdCase View Post
Older thread, but I always thought you often to release the parking brake cable tension in order to get enough parking pad clearance to remove the rear rotors.
Meh...........not that old, and yes, you pretty much always have to release the parking brake in order to pull the drum or rotor (either) on the rears.
~Mike~
WK
XJ
JeepN4KC is offline
