Removing Lower Control Arm - JeepForum.com
post #1 of 20 Old 03-19-2015, 09:54 AM Thread Starter
huntb
2008 KK Liberty
Anyone know where I can find a write up on how to remove an LCA? I need to replace my terribly squeaky bushings
huntb is offline
post #2 of 20 Old 03-19-2015, 11:40 AM
pshivers
2008 KK Liberty
Service manuals are at my house. I can tell you in a couple weeks.
Should be something like, pop out the ball joint and remove two bolts in the lca.
pshivers is offline
post #3 of 20 Old 03-19-2015, 03:33 PM
NAMoulton
2010 KK Liberty
Removing the lower control arm will REQUIRE an alignment. The LCA has the camber set washers in place and removing them to reinstall would leave a slight to drastic change.
Custom/JBA 4.5" Lift-16x8 M13 Rims-265/75 Pro Comp MT2s-Yukon 4.56s-Rear Ox Locker-Front DTT
NAMoulton is offline
post #4 of 20 Old 03-19-2015, 05:10 PM
tommudd
2004 KJ Liberty
Pretty easy really to remove
Up on jackstands, jack under the control arm
Remove lower ball joint
sway bar link etc
mark where the camber bolts are set at ( that way when it goes back together it'll be somewhere close)
Remove the two camber bolts and drop it down out
Are you sure its one of the bushings in the LCA? Very seldom here of that
Mine are stock with over 200,000 and no noise
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #5 of 20 Old 03-20-2015, 09:11 AM
Gageraid
2008 KK Liberty
Is it on both sides?
If it's on the passenger side, check your CAI heat shield if you have one installed.
Mine was rubbing on the inner fender and I thought it was the LCA. Took many days before I figured that one out.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline
post #6 of 20 Old 03-21-2015, 06:19 AM Thread Starter
huntb
2008 KK Liberty
In order to get it out of the knuckle I have to take the clevis off though right? I got that far last time and there wasn't enough room to lift the ball joint out of the knuckle because the hub was interfering.
Tom - I have no idea but I've replaced my UBJ, pulled out my tie rod and the ball joint felt fine. I've removed my sway bar entirely and it wasn't that. Like I said I popped out the LBJ and that seemed to MO e freely as well. The only thing I haven't done is remove the upper and lower control arms entirely. The creaking noise is extremely loud and it does it while turning the wheel and during any suspension articulation. It certainly isn't a heat shield, it sounds far worse. Could it be my steering rack?
huntb is offline
post #7 of 20 Old 03-21-2015, 06:45 AM
pshivers
2008 KK Liberty
Will it make the noise while stationary if you compress the suspension or do you have to be moving?
pshivers is offline
post #8 of 20 Old 03-21-2015, 07:10 AM Thread Starter
huntb
2008 KK Liberty
Yes, even when stationary. It even does it when I close the door too hard.
huntb is offline
post #9 of 20 Old 03-21-2015, 07:49 AM Thread Starter
huntb
2008 KK Liberty
So I pulled the tierod so I can turn the hub by hand and the noise is there but very hard to tell where it is coming from. Could it be from on of the CV joints on the axle?
And my follow up to this is - does anyone have a writeup on replacing an axle? SMH...
huntb is offline
post #10 of 20 Old 03-21-2015, 03:43 PM
tommudd
2004 KJ Liberty
Remove caliper, brakes, tie rod , unbolt CV of course, pop off the lower and upper control arms ( ball joints) remove spindle, pull out CV
MUDD'S MOTORSPORTS
tommudd is offline
post #11 of 20 Old 03-23-2015, 05:35 AM Thread Starter
huntb
2008 KK Liberty
I'm guessing that I'll also have to remove the clevis? Thanks Tom, got a new one on order
huntb is offline
post #12 of 20 Old 03-24-2015, 05:58 PM Thread Starter
huntb
2008 KK Liberty
Good news! I have the new half shaft installed!
Bad news... the half shaft wasn't the issue. I believe its the lower ball joint and it doesn't look replaceable... can anyone confirm? Do I really need to buy a whole new LCA?
huntb is offline
post #13 of 20 Old 03-24-2015, 06:10 PM
lfhoward
2008 KK Liberty
More good news... Lower ball joints can be replaced without replacing the LCA (unlike the UBJ & UCA). Mine have been done already. I have greasable LBJ's in there now.
2008 Liberty Sport 4x4 Automatic
lfhoward is offline
post #14 of 20 Old 03-24-2015, 07:40 PM
Bmxer524
2011 KK Liberty
Part numbers? lol I'd like to know for the future
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #15 of 20 Old 03-24-2015, 08:40 PM Thread Starter
huntb
2008 KK Liberty
Wonderful news. Now that I have it all put back together I can't wait to take it all apart again and press that rusty piece of crap out
huntb is offline
