Removing Brake Caliper - JeepForum.com
post #1 of 3 Old 02-22-2010, 10:19 AM Thread Starter
MikeFinn
1995 XJ Cherokee
I went to change my girlfriends brake pads on her 2008 and was wondering if anyone knew how to remove the calipers. When i went to remove the 2 bolts from behind the calipers it looks like there is a nut on the bolt in the middle. I thought id check her before i attempt to remove it. The problem i am having is that there isnt enough room to get a wrench on the nut. Do i need a slimmer wrench or is there something im missing?
Thanks Mike
MikeFinn is offline
post #2 of 3 Old 02-22-2010, 11:44 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
There should just be 2 bolts holding the caliper to the knuckle and another in the middle that holds the brake line to the caliper but dont remove the middle unless you plan on cleaning up brake fluid
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 3 Old 02-22-2010, 12:44 PM Thread Starter
MikeFinn
1995 XJ Cherokee
Wish i took a picture and i guess i didnt describe it very well. It looks like the bolts screw the calipers into the caliper pins. But i am unable to get a wrench (too thick) on the end of the pins to back off the bolts.
not sure if the parts link works
RockAuto Parts Catalog
MikeFinn is offline
Parking Brake adjustment '08 Liberty 08liberty KK Liberty Forum 22 05-22-2017 12:31 PM
Chrysler Recalls for Possible Brake Failure mike79 KK Liberty Forum 0 01-18-2010 11:01 AM
Removing Turn Signals? 2009 KK JFD140 KK Liberty Forum 4 12-22-2009 11:51 AM
