Rear Hatch Water Leak - JeepForum.com
post #1 of 2 Old 04-17-2013, 07:40 AM Thread Starter
Eagle112199
2010 JK Wrangler
Does anyone have a problem with the glass hatch leaking water sometimes in a hard rain? Is the seal bad and/or can it be replaced? Thanks!
Jeep: It's a passion, not an obsession.
2010 JK Wrangler 2-Door
Soft Top
Eagle112199 is offline
post #2 of 2 Old 04-17-2013, 07:50 AM
Ted15
2010 KK Liberty
I had that problem with mine. You'll need the window seal for the flipper glass and an additional piece that looks like a rain gutter. It fits across the top of the glass and diverts water to the sides. If you're having problems with the dome light staying on and gate appears across the speedometer then you'll also need a gate switch because of water damage. There's also the possibility that the center brake light gasket is bad but that's not likely to be the case.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
