rear axle oil capacity - JeepForum.com
post #1 of 4 Old 10-29-2010, 10:36 PM Thread Starter
VMF
2008 KK Liberty
so i finally got to changing oil in my rear axle. it was pretty darn dirty after almost 27k. and cleaning old silicone with the bar and spare tire there was no fun either. anyway, after i poured 2 bottles in the level was still not at the filler hole but like 3-5 mm lower. it was late and all stores were closed so i plugged the hole and drove home. is it ok to have the level lower then the hole or should i fill it up?
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #2 of 4 Old 10-29-2010, 11:10 PM
danielsCJ
1982 CJ7
Fill to the Hole
danielsCJ is offline
post #3 of 4 Old 10-30-2010, 09:51 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
You dont want to over fill it as when in use it heats up and expands. If i recall it should be about 2 bottles. Usually i measure what came out and put the same amount back in
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #4 of 4 Old 10-30-2010, 12:59 PM
richd
2008 KK Liberty
The rear differential capacity is 4.3 pints.
richd is offline
08 KK Liberty COMMAND-TRAC Transfer Case capacity mjcougler KK Liberty Forum 48 11-29-2016 05:54 PM
axle oil change, how much oil do i need? VMF KK Liberty Forum 10 12-15-2011 09:28 PM
Front and Rear axle lubricant change jeeps4us KK Liberty Forum 20 10-24-2010 11:11 AM
Rear axle info? gunselman KK Liberty Forum 1 09-02-2010 11:40 AM
Why is the Sport limited to only 3500lb tow capacity? KDOG2008 KK Liberty Forum 3 06-20-2010 07:18 PM
