Really Bad Thud/Pop from Steering Rack Area - JeepForum.com
post #1 of 5 Old 02-14-2010, 05:28 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
So basically i have a ridiculously bad thud/ pop noise coming from near the driver side of the my Jeep. This at first only happened when i was stopped and it happened once in a while, but now it is happening at all speeds, stopped, you name it. I got underneath while someone turn the wheel back and forth and the popping noise is coming from above the engine skid plate like its the steering rack. If i place a hand on the outer tie rod while the wheel is being turned back and forth you can feel clicking kinda. If i place a hand on the UCA or Stabalizer link i feel nothing so its got to do with the steering rack/ Tie Rods. Also when at full lock, the steering growns Any ideas?
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #2 of 5 Old 02-15-2010, 03:22 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Does the power steering fluid need to be checked with the vehicle off or on?
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 5 Old 02-19-2010, 12:08 PM
09_Silver
2011 KK Liberty
You'll want to check your power steering fluid with the engine turned off. As for your clunking noise what I would do is pull the wheel off, remove the strut and UCA. Check for anything obvious like a loose bolt. Then re-install the UCA and the strut and make sure everything is really tight. Then see if the noise went away. I'm no expert, but that's what I would do.
'11 Liberty Jet Sport - 4x4
09_Silver is offline
post #4 of 5 Old 02-19-2010, 01:46 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Its at the Dealer now, ill keep you posted on results
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #5 of 5 Old 02-19-2010, 09:36 PM Thread Starter
Elt31987
Elt31987's Avatar
2008 KK Liberty
Dealer says they found the problem. The Camber bolts were loose and they were sliding around. I had an alignment done like a month ago so looks like i will be going back to the alignment shop to find out why they werent tightened properly and to argue over the 106.00 the dealer charged me for 1 hour of labor. Anyway, which bolts are the camber bolts? The LCA bolts?
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
'10 soft top liberty with roof rack?? turkish6 KK Liberty Forum 2 10-02-2011 04:38 PM
Need size of cargo area Boonking KK Liberty Forum 4 01-17-2010 10:58 AM
