Rattling on driver side door - JeepForum.com
post #1 of 20 Old 06-20-2012, 04:23 PM Thread Starter
dtbingle
2011 KK Liberty
Right now I only have the stock speakers in my liberty right now and there is a rattling when I turn the bass a couple notches up or if i turn my volume pretty high. When I press on the plastic area above the door handle, it goes away. Does anyone else experience this and know how to get rid of it? It's not a huge issue, but I'm considering some aftermarket speakers/sub soon and if it rattles with the stock ones, I'm assuming it's going to be much worse with an aftermarket setup with a lot more kick.
dtbingle is offline
post #2 of 20 Old 06-20-2012, 08:47 PM
scorpionarmor55
2010 KK Liberty
I recently noticed the same. Took off all the door Panels and glued down the edges of that insulation inside and it was good to go.
scorpionarmor55 is offline
post #3 of 20 Old 06-20-2012, 09:40 PM
VegasDragger45
2010 KK Liberty
I had the same issue and it was from the bass coming into the door speakers and making stuff rattle. Once I changed out all the speakers and added a sub i took all bass out of the doors and it solved my issue and saved me time tracking down the noise. If you change your speakers it should do the same for you.
2010 KK, 2" Daystar lift, 245/75/16 BFG All-Terrains, interior LED's, front rear and cargo liner weather tech's, Pioneer AVH-p4400BT, GEX-P920XM, Kicker 6" in front 5 1/4" in rear, PB 2.75" in dash, Kicker 300.1 amp, Pioneer TS-SWX310, JK light bar with Hella 500 ff and 100w bulb, BOYO rear view camera, JBA exhaust, K&N drop in filter and more to come.
VegasDragger45 is offline
post #4 of 20 Old 06-21-2012, 05:43 PM Thread Starter
dtbingle
2011 KK Liberty
Hmmm guess I HAVE to change/upgrade all my speakers and add a sub then. One more reason to put aftermarket audio equipment in lol. If it still happens afterwards I'll look to glue that insulation. Thanks
dtbingle is offline
post #5 of 20 Old 06-24-2012, 10:35 AM
bagwell
2011 KK Liberty
ok finally tired of the rattle, then I starting geting a horrible creaking noise when I rested my elbow on the driver's door armrest.
Popped the door panel off and applied stick-on felt pieces to every single place the door panel attaches to the door (which is plastic on plastic) --- there's about 10 different places.
PROBLEM SOLVED!!! Driver's door is as quiet as a mouse --- no creaks or rattles from bass!! Now for the passenger side!!
bagwell is offline
post #6 of 20 Old 06-24-2012, 11:24 AM
marlon_jbt
2010 KK Liberty
Where can those stick on felt pieces be found?
Red Jeep Club member # 264
marlon_jbt is offline
post #7 of 20 Old 06-24-2012, 11:35 AM
bagwell
2011 KK Liberty
walmart has them....the light duty...not the thick pads.
it is NOT the thick type like this ---
bagwell is offline
post #8 of 20 Old 06-24-2012, 01:41 PM
bagwell
2011 KK Liberty
Also, there's a pretty thick paper covering the speakers in the front doors....I removed this; I figured it might let more treble come thru altho I noticed little to no difference afterwards. It also might be part of the rattling issue with bass (vibrating against the outer door panel??).
I'm doing the pass side door now.
bagwell is offline
post #9 of 20 Old 06-24-2012, 09:04 PM Thread Starter
dtbingle
2011 KK Liberty
I've been driving with my windows down almost all the time because of the nice summer weather, but considering it rained decent tonight, the windows were up. It was noticeably worse with them up rather than down. Is there any chance you could get a picture of where you're putting those felt pieces on?
dtbingle is offline
post #10 of 20 Old 06-25-2012, 08:21 AM
musclezmarinara
2012 KK Liberty
does that fix the big rattles from the infinity stereo system ?
2012 KK Cherokee * Arctic * Mineral Gray
- Mods - See Build Thread..
musclezmarinara is offline
post #11 of 20 Old 06-25-2012, 08:46 AM
bagwell
2011 KK Liberty
I just have the base system and it fixed all mine...very happy camper now. I applied some extra felt pieces around the door speaker (there's some really flimsy foam all around the speaker).
once you pop the outer door panel off you will see about 10 tabs that slide onto the inner door panel...anywhere these contact one another is a possible rattle/creak/squeak point....I guess you could put 100 of those pieces to be safe
bagwell is offline
post #12 of 20 Old 06-25-2012, 08:51 AM
musclezmarinara
2012 KK Liberty
well it fixed all mine.
I shall try it
post #13 of 20 Old 06-30-2012, 09:28 PM Thread Starter
dtbingle
2011 KK Liberty
Bought some of that light duty stick on felt stuff and finally got around to doing it. Fixed the passenger side right up and I thought I had done the driver side the exact same, but apparently not because still getting that rattling sound. After try number two, still couldn't get the dang driver side door to stop. Tomorrow I'm going at it again and this time the inside of the door is getting coated in felt...hope it works!
dtbingle is offline
post #14 of 20 Old 07-01-2012, 09:13 AM
bagwell
2011 KK Liberty
more the better!!!
also cut some of the pieces and stick on top of the flimsy foam thats around the door speakers....I stuck about 4 pieces on there.
if you still have the stock speakers, get rid of that paper coating.
bagwell is offline
post #15 of 20 Old 07-01-2012, 01:47 PM Thread Starter
dtbingle
2011 KK Liberty
more the better!!!
I will try this next! It definitely seems to be rattling somewhere behind the small panel surrounding the door handle so I'll start there!
dtbingle is offline
How to replace driver's side headlight bulb? jleighhester KK Liberty Forum 16 01-06-2015 11:00 AM
Driver's side door lock 2009 Liberty Jeff88 KK Liberty Forum 9 05-14-2012 06:48 PM
2 Door KK? (Spiritual successor to the 2 door XJ) C_ee_X KK Liberty Forum 8 04-08-2012 12:53 PM
Driver side window switch - 2008 stumpjumper397 KK Liberty Forum 4 08-05-2011 12:05 PM
Interior Rattling ChrisPearce8841 KK Liberty Forum 1 01-16-2011 01:22 PM
