-   KK Liberty Forum (http://www.jeepforum.com/forum/f292/)
-   -   Rattling on driver side door (http://www.jeepforum.com/forum/f292/rattling-driver-side-door-1383644/)
dtbingle 06-20-2012 04:23 PM
Right now I only have the stock speakers in my liberty right now and there is a rattling when I turn the bass a couple notches up or if i turn my volume pretty high. When I press on the plastic area above the door handle, it goes away. Does anyone else experience this and know how to get rid of it? It's not a huge issue, but I'm considering some aftermarket speakers/sub soon and if it rattles with the stock ones, I'm assuming it's going to be much worse with an aftermarket setup with a lot more kick.
scorpionarmor55 06-20-2012 08:47 PM
I recently noticed the same. Took off all the door Panels and glued down the edges of that insulation inside and it was good to go.
VegasDragger45 06-20-2012 09:40 PM
I had the same issue and it was from the bass coming into the door speakers and making stuff rattle. Once I changed out all the speakers and added a sub i took all bass out of the doors and it solved my issue and saved me time tracking down the noise. If you change your speakers it should do the same for you.
dtbingle 06-21-2012 05:43 PM
Hmmm guess I HAVE to change/upgrade all my speakers and add a sub then. One more reason to put aftermarket audio equipment in lol. If it still happens afterwards I'll look to glue that insulation. Thanks
bagwell 06-24-2012 10:35 AM
ok finally tired of the rattle, then I starting geting a horrible creaking noise when I rested my elbow on the driver's door armrest.
Popped the door panel off and applied stick-on felt pieces to every single place the door panel attaches to the door (which is plastic on plastic) --- there's about 10 different places.
PROBLEM SOLVED!!! Driver's door is as quiet as a mouse --- no creaks or rattles from bass!! Now for the passenger side!!
marlon_jbt 06-24-2012 11:24 AM
Where can those stick on felt pieces be found?
bagwell 06-24-2012 11:35 AM
walmart has them....the light duty...not the thick pads.
http://1.bp.blogspot.com/_ZtKYr4Kzqf...MGP1704fix.jpg
it is NOT the thick type like this --- https://encrypted-tbn1.google.com/im...bocn7YcQKZBOOg
bagwell 06-24-2012 01:41 PM
Also, there's a pretty thick paper covering the speakers in the front doors....I removed this; I figured it might let more treble come thru altho I noticed little to no difference afterwards. It also might be part of the rattling issue with bass (vibrating against the outer door panel??).
I'm doing the pass side door now.
dtbingle 06-24-2012 09:04 PM
I've been driving with my windows down almost all the time because of the nice summer weather, but considering it rained decent tonight, the windows were up. It was noticeably worse with them up rather than down. Is there any chance you could get a picture of where you're putting those felt pieces on?
musclezmarinara 06-25-2012 08:21 AM
does that fix the big rattles from the infinity stereo system :) ?
bagwell 06-25-2012 08:46 AM
I just have the base system and it fixed all mine...very happy camper now. I applied some extra felt pieces around the door speaker (there's some really flimsy foam all around the speaker).
once you pop the outer door panel off you will see about 10 tabs that slide onto the inner door panel...anywhere these contact one another is a possible rattle/creak/squeak point....I guess you could put 100 of those pieces to be safe :2thumbsup::2thumbsup:
musclezmarinara 06-25-2012 08:51 AM
well it fixed all mine.
I shall try it :)
dtbingle 06-30-2012 09:28 PM
Bought some of that light duty stick on felt stuff and finally got around to doing it. Fixed the passenger side right up and I thought I had done the driver side the exact same, but apparently not because still getting that rattling sound. After try number two, still couldn't get the dang driver side door to stop. Tomorrow I'm going at it again and this time the inside of the door is getting coated in felt...hope it works!
bagwell 07-01-2012 09:13 AM
more the better!!!
also cut some of the pieces and stick on top of the flimsy foam thats around the door speakers....I stuck about 4 pieces on there.
if you still have the stock speakers, get rid of that paper coating.
dtbingle 07-01-2012 01:47 PM
Originally Posted by bagwell (Post 13802538)
more the better!!!
I will try this next! It definitely seems to be rattling somewhere behind the small panel surrounding the door handle so I'll start there!
The time now is 11:32 PM.
