Radio Wiring help - JeepForum.com
post #1 of 3 Old 11-07-2010, 04:26 PM Thread Starter
CRSTWGN
2010 KK Liberty
Radio Wiring help
I drive a 2010 Liberty and am trying to install a line out converter, amp and subs, however i have been trying to find a wiring diagram with the list of colored wires. I need to find the ignition wire and the back seat door speaker wires. Thanks in advance.
CRSTWGN is offline
post #2 of 3 Old 11-07-2010, 05:41 PM
PlatinumNiner
There is no ignition wire it's turned on through data whatever you do dont start trying to probe wires behind the radio. There are CAN high and CAN low wires behing there and if you probe them wrong you will fry your computer. They go directly back to the computer. Stay away from the white and white/orange wire that are twisted together. Those are the CAN wires Last vehicle i saw that an installer screwed up was a 2009 silverado. $7000 later the truck was back on the road lol.
As for ignition, go to the lighter or fuse box.
Rear right speaker + dark green/light green - kark green/gray
Left rear speaker + gray/light green - gray/dark green
Good luck.
PlatinumNiner is offline
post #3 of 3 Old 11-13-2010, 09:45 AM
SuperRliBerty
2008 KK Liberty
Platinum miner is right! stay away from the CAN sheilded wires. below is a pin out and pics of the connector
Radio C1 - Gray 10 way
Hands Free (U-Connect)
Code:
1 18LB/DG LEFT AUDIO OUTPUT
2 18DG/LB RIGHT AUDIO OUTPUT
3 -
4 18DG/YL MICROPHONE FEED
5 -
6 18DG COMMON AUDIO OUTPUT
7 18LB/DG MICROPHONE IN (-)
8 18OR/GY SENSOR GROUND
9 -
10 -
Radio C2 - Gray 22 way
Audio
Code:
1 18RD FUSED B(+) (I.O.D.)
2 20WT CAN INTERIOR BUS (-)
3 -
4 -
5 -
6 -
7 18GY/OR AMPLIFIED ANTENNA FEED
8 18GY/LG LEFT REAR SPEAKER (+)
9 18GY/DG LEFT REAR SPEAKER (-)
10 18DG/LG RIGHT REAR SPEAKER (+)
11 18DG/GY RIGHT REAR SPEAKER (-)
12 18BK/WT GROUND
13 20WT/OR CAN INTERIOR BUS (+)
14 -
15 -
16 -
17 -
18 -
19 18DG/VT RIGHT FRONT SPEAKERS(+)
20 18DG/YL RIGHT FRONT SPEAKERS(-)
21 18GY/VT LEFT FRONT SPEAKERS(+)
22 18GY/YL LEFT FRONT SPEAKERS(-)Radio C3 - White 22 way
Rear-Seat Video Montior
Code:
1 18GY/LB AUDIO RETURN 3
2 -
3 -
4 -
5 18GY/BR VIDEO SIGNAL 1
6 18GY/YL VIDEO COMMON 1
7 VDO-VIDEO SHIELD 1
8 18GY/LB VIDEO SIGNAL 2
9 18GY/YL VIDEO COMMON 2
10 VIDEO SHIELD 2
11 18GY/OR AUDIO RETURN 2
12 18DG/VT AUDIO LEFT 3
13 18DG/YL AUDIO RIGHT 3
14 -
15 -
16 -
17 -
18 18DG/TN AUDIO LEFT 1
19 18GY/VT AUDIO RETURN 1
20 18DG/WT AUDIO RIGHT 1
21 18DG/LB AUDIO LEFT 2
22 18DG/DB AUDIO RIGHT 2
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
standard radio vs. touch screen hard drive..? AdventurerSport KK Liberty Forum 7 12-22-2010 07:58 PM
Please help me with harness for aftermarket radio! atti_magnolia KK Liberty Forum 9 11-13-2010 10:22 AM
Trailer Wiring Help MikePM KK Liberty Forum 2 10-31-2010 04:41 PM
Getting Liberty on monday! Radio question... Tanya KK Liberty Forum 6 10-08-2010 08:48 PM
Removing the sunglass tray above radio JFD140 KK Liberty Forum 1 04-14-2010 03:19 PM
