Radiator recommendation - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Radiator recommendation
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectSave on Warn Winches and TENOFF Promotion!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-13-2015, 12:23 PM   #1
snookumsthacat
2008 KK Liberty
So, I recently was trying to figure out why my transmission fluid was soo much higher than it should be with the special tool dipstick I ordered. I had also been looking for a coolant leak as I've been filling my coolant reservoir every other month. Low and behold, after seeing my coolant in my radiator as a pink milky substance, I realized my transmission cooler had cracked inside the radiator and the fluids have been contaminating each other. Knowing now I have alot of flushing to do and a radiator change, I've been looking at replacement radiators. The dealership will sell one for 210 dollars, but I'm not sure the longevity of that since this current radiator was the original equipment. Does anyone have any other recommendation? I'd really like to avoid this ever happening again
Thanks in advance
snookumsthacat is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 01:55 PM   #2
tjkj2002
2002 KJ Liberty
No internal radiator trans cooler on a KK so what your seeing is not ATF.The only thing it can be is engine oil.
tjkj2002 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 05:15 PM   #3
snookumsthacat
2008 KK Liberty
man.. so that means I get to tear the engine apart and change the head gaskets.. one horrendous problem after another.. I wish I had never bought this 6 year old mopar.
Unread 01-13-2015, 05:56 PM   #4
tjkj2002
2002 KJ Liberty
Well that means it was severely overheated at some point,either you or the 1st owner if you bought it used.Not the vehicles fault but owner neglect.
Unread 01-13-2015, 06:54 PM   #5
02jeepliberty
x2
02jeepliberty is offline   Reply With Quote Quick reply to this message
