Question regarding TPMS (Tire Pressure Monitoring System) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Question regarding TPMS (Tire Pressure Monitoring System)
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line~Artec JK 1 TON SWAP~Advance Adapters SYE Kits
Unread 10-12-2014, 03:30 PM   #1
gt5oh
As I was driving today, the ( ! ) Caution light came on.
It pointed out that there was an issue with the TPMS Sensor and as I cycled through to the air pressure I noticed that no tire had any number displayed.
It now showed every wheel as -
I shut the car off, and upon starting ti back up, the Caution light comes back on, the car chimes 4 times, and it shows TPMS Error.
Tire pressures are normal as I checked them with a gauge. Anyone know whats causing this issue? Thanks
2008 Liberty Limited about 39,000 miles on it.
gt5oh is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 04:08 PM   #2
lfhoward
2008 KK Liberty
Since you have a 2008, it's possible that some of your tire sensors have low or dead batteries. On my 2008, I only have 2 original TPMS sensors left, and the rest have been replaced for various reasons (dead battery, valve stem breaking).
2008 Liberty Sport 4x4 Automatic
lfhoward is online now   Reply With Quote Quick reply to this message
Unread 10-12-2014, 05:06 PM   #3
gt5oh
Interesting.. didn't realize they go bad due to battery.
But more importantly, is what happened to the car all at once while I was driving that would cause that caution to come up and all 4 to not display pressures?
Unread 10-12-2014, 05:42 PM   #4
lfhoward
2008 KK Liberty
That I don't know. I have the Sport version, without the EVIC. When my TPMS go off there is only a tire light, with no indication of which one might be the problem. One other thing to check would be the pressure in your spare, if you have the full sized spare. (No TPMS in the donut spare)
Unread 10-12-2014, 06:20 PM   #5
LibertyRS
2012 KK Liberty
I'd stop by discount tire. They can scan your sensors for free. That way you know which one is bad if any are.
If its solid that means there is a problem with sensor itself whether it be broken, dead battery, etc
If its blinking it just means the air pressure is at the wrong psi.
If you have any broken ones I have a few sets from changing my wheels so often. Ill give ya the homie jeep it real special.
2012 Jeep KK
Stormtrooped
ZZzz
LibertyRS is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 06:51 PM   #6
gt5oh
Thanks for the advice I will go to the one of the auto chains who can scan the sensors thank you.
Unread Yesterday, 03:14 PM   #7
Ted15
Ted15's Avatar
2010 KK Liberty
mine's doing the same thing. NTB told me to take it to the dealer, their scanner doesn't detect what's wrong. The guy doesn't think it's related to the sensors though.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline   Reply With Quote Quick reply to this message
