Problems with Auto lights and climate contral - JeepForum.com
post #1 of 5 Old 09-27-2013, 11:43 AM Thread Starter
Slayers
2008 KK Liberty
Well since I only get to drive the Jeep 1 time a week I don't often get a chance to see if things are wrong but this am I woke up to the engine light on.
It was a small leak and I reset the light but after that I noticed that the auto lights where no coming on and even thou I had the controls on hot and defrost it was still blowing cold and out of the front vents.
Has anyone else had this problem? And what was replaced when you had it fixed?
Slayers is offline
post #2 of 5 Old 09-27-2013, 08:44 PM
Gageraid
2008 KK Liberty
A small leak where?
Gageraid is offline
post #3 of 5 Old 10-06-2013, 12:21 AM
medic455
2010 KK Liberty
Well I have had issues off and on with my KK as well. Take out fuse 13 in the fuse box, and put it back in. Has worked 2 times on mine. Fuse was ok, but I guess maybe loose.
2010 Jeep KK Limited loaded up.
medic455 is offline
post #4 of 5 Old 10-07-2013, 04:40 AM
TJ's02TJ
I have the same problem with the auto lights as well. They worked great when I first got it but not at all anymore. As far as the climate control, I have experienced that same thing but only once or twice. I just turned the temp knob from hot to cold and back to hot and the air then began to get warm.
2004 Wrangler TJ 2.5" lift with 31s.
2012 KK Liberty. (Waiting it's turn for a lift)
TJ's02TJ is offline
post #5 of 5 Old 10-07-2013, 11:44 AM Thread Starter
Slayers
2008 KK Liberty
I did the same with mine reset the MIL and then pulled the fuse and now everying seems to work.
Slayers is offline
