Problems at 2000-2500rpm - JeepForum.com
post #1 of 4 Old 08-04-2010, 04:44 AM Thread Starter
redmario
2010 KK Liberty
Hi,
I'm from Italy and I have a new liberty kk (my2010), crd 2.8, with manual gear.
My problem appear when the engine is about 2000 to 2500 rpm (gear 4th, 5th and 6th less with 3rd)... the engine isn't flowing but little jumping. It seems flooding.
Have you the same problem? Have you a solution?
Thank you everybody.
redmario is offline
post #2 of 4 Old 08-04-2010, 11:46 PM
richd
2008 KK Liberty
Originally Posted by redmario View Post
Hi,
At what speed does this happen?It sounds like the engine is lugging,maybe putting it in to high of a gear to soon.
richd is offline
post #3 of 4 Old 08-06-2010, 04:15 PM Thread Starter
redmario
2010 KK Liberty
At 90 Km in 4th, 100 Km in 5th and 110 Km in 6th.
The problem appears only between 2000 and 2500 rpm and with constant speed. Accelerating, when the engine goes over 2500 it's very imperceptible.
Someone says that dependes on the settings of the central unit that does not handle well the EGR valve.
It's possible?
redmario is offline
post #4 of 4 Old 08-06-2010, 06:33 PM
richd
2008 KK Liberty
It's possible?
You seem top be shifting it OK,This should still be under warranty,If you can tell the dealer the problem,and see what they say.They could try to reprogram the PCM and see if that helps.
richd is offline
SKY SLIDER leaking problems! CDigs KK Liberty Forum 74 01-24-2016 04:03 PM
MyGIG uploading problems davejlaw KK Liberty Forum 2 11-13-2010 07:59 PM
problems ? ajyadouga KK Liberty Forum 11 07-06-2010 01:24 PM
