Power mirrors not working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Power mirrors not working
Bds fox ipf 2.0 racing series shocks now available at rockThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 08-20-2014, 02:29 PM   #1
TKP
2011 KK Liberty
My 2011 Jeep Liberty Sport's power mirrors are not working---not even sporadically. Both sides are not functioning. I am assuming the problem is either in the driver side wiring, or in the fuse box? I've tried to find an answer online, but haven't been able to resolve the problem...and really I'm not sure where to start. Any help would be much appreciated!
Thanks
TKP is offline   Reply With Quote Quick reply to this message
Unread 08-21-2014, 07:58 AM   #2
JeepCares
FCA Customer Care
JeepCares's Avatar
See attached for fuse location.
From the factory service manual:
The power mirror system includes two selector switches and an adjuster switch that are located on the driver front door trim panel and are only serviced as an integral part of the driver front door power switch module.
Ryan
Jeep Social Care Specialist
JeepCares is offline   Reply With Quote Quick reply to this message
Unread 08-21-2014, 09:56 AM   #3
TKP
2011 KK Liberty
So if I understand correctly, its likely the fuse for the power mirrors--since the rest of my driver door components are working correctly?
Unread 08-21-2014, 01:16 PM   #4
JeepCares
FCA Customer Care
JeepCares's Avatar
I'm not diagnosing it. Checking the fuse won't cost you anything but a few minutes of time.
Ryan
Unread 08-21-2014, 01:56 PM   #5
josworth
2010 KK Liberty
Wow...
OK, let me try and help you further.
Yes, always check fuses first. They are listed in your owners manual.
Next step would be to pull the door switch out and check for power at the wires going into the mirror switch. Without a wire diagram maybe a hit or miss on finding the hot. Thing is if you don't find any hot wire when you should, it's not the switch and could either be the wiring itself or a module. If you get power but the mirrors don't work, then test for output power when adjusting the mirror. No output power but input OK = Bad Switch.
BTW, you can use those basic diagnostic steps with a Volt Meter to test just about any switch.
josworth is offline   Reply With Quote Quick reply to this message
Unread 08-22-2014, 09:51 AM   #6
TKP
2011 KK Liberty
Well I checked the fuse, and it is good. I will check the wires next. Thanks for your help!
By chance, can you point me to somewhere/thing on how to get the door switch out to check the wiring?
Unread 08-22-2014, 11:02 AM   #7
josworth
2010 KK Liberty
I believe it just pops out, but I will check in the service manual I have to be sure, tonight.
Jeff
2010 Honda Crosstour AWD-V6
