POS turn signal - JeepForum.com
post #1 of 2 Old 10-17-2010, 11:54 PM Thread Starter
slick2570
POS turn signal
My girlfriend has an 08 Liberty and sometimes when you make a turn with your blinker on it will blink 3 or 4 times in the opposite direction after it clicks back into place. Anyone else have this problem? Is it a bad relay or something that can be fixed, or do i need to replace the whole lever assembly itself? Thanks
-Eric
2003 TJ Rubicon - stock for now
1999 WJ - Gone
slick2570 is offline
post #2 of 2 Old 10-18-2010, 05:51 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Ive accidentally pushed the blinker in the wrong direction and then when i try to correct myself and click it the correct way it still blinks 3 times in the original/wrong way. This is because if you push the blinker slightly but not till it clicks it will blink 3 times. This makes it easier for highway lane changing.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
Removing Turn Signals? 2009 KK JFD140 KK Liberty Forum 4 12-22-2009 12:51 PM
