PLZ Help, Problem with Irregularity after starting - 2008 KK - JeepForum.com
post #1 of 8 Old 08-10-2010, 05:52 AM Thread Starter
nawras_20
2008 KK Liberty
Dears,
I have KK 2008 Limited Edition,
The Problem
After starting the engine normally, 30 Sec later, Irregularity took place in the engine (during the instability SOMETIMES the check engine indicator light is appear and disappear if I didn't push the accelerator pedal ),
After that the engine get stable and it working normally till you switch off the engine and the check engine indicator still appear.
I Did the following
1) Replaced the fuel pump's filter inside the fuel tank.
2) Opened the Nozzles injectors and check and clean it, its working properly.
3) Replaced the 6 spark plug with new recommended one.
4) Did many computer checks to the car without get a clear error in any sensor, except the O2 sensors (slow response) and this fault is common here in Iraq since we use very bad quality Fuel).
And one of the Guys working in Jeep dealer told me that the problem is with the Fuel Evaporator which located under the back bumper.
I'm really get confused, and I need your help especially who have experience in this issue
Eng. Nawras
Baghdad
nawras_20 is offline
post #2 of 8 Old 08-10-2010, 10:11 PM
richd
2008 KK Liberty
If your CEL was on,you should have a code.If you can give us the code,then we can help you.
richd is offline
post #3 of 8 Old 08-11-2010, 03:02 AM Thread Starter
nawras_20
2008 KK Liberty
Dear Richd,
The Problem because the slow response of the Oxygen sensors,
but this error was exist from long time and the car working properly,
and know, the instability of the engine with the same error,
Thanks
post #4 of 8 Old 08-11-2010, 01:19 PM
richd
2008 KK Liberty
Originally Posted by nawras_20 View Post
Dear Richd,
Thanks
There are several codes for slow response,plus each code tells us which O2 sensor circuit is involved.There are 4 O2 sensors so knowing the code will tell us which sensor circuit to look at.Here are cause of slow response:
Exhaust leak present in the exhaust manifold or exhaust pipes
O2 signal circuit or upstream or downstream circuit has failed
O2 element has failed
richd is offline
post #5 of 8 Old 08-11-2010, 03:48 PM Thread Starter
nawras_20
2008 KK Liberty
So You think this instability of the engine because of the O2 senors?
post #6 of 8 Old 08-11-2010, 06:38 PM
richd
2008 KK Liberty
If your code said slow response,then yes,but the wiring should be checked out first,check for exhaust leak,then the O2 sensor.Like I said before the code will tell you which sensor circuit to check.If you knew the code,I can tell you which sensor circuit is giving you the problem.
richd is offline
post #7 of 8 Old 09-26-2010, 05:00 AM Thread Starter
nawras_20
2008 KK Liberty
Thanks dear for your help,
I have replaced all the O2 sensors,
and my car become great without any instability
post #8 of 8 Old 09-26-2010, 03:45 PM
richd
2008 KK Liberty
Im glad to help out.Good Luck.
richd is offline
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 07:02 PM
2008 Liberty Skyslider Issues JFK2218 KK Liberty Forum 39 04-05-2012 12:31 PM
2008 Liberty mechanical fan noise JWMII KK Liberty Forum 2 11-21-2010 09:09 AM
Fuse problem in my 2008 KK....NOT! A RODENT! Huntyeraws KK Liberty Forum 12 07-14-2010 07:51 AM
2008 KK lift? GilNewJeeper KK Liberty Forum 6 01-05-2010 09:19 PM
