Pics of the little things you've done interior/ exterior - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > Pics of the little things you've done interior/ exterior
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 09-13-2013, 01:44 PM   #61
_benjammin
2012 KK Liberty
Originally Posted by staubitzk View Post
Check out http://customkk.com as there are a ton of pics of custom kks.
Fail
_benjammin is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 01:08 PM   #62
bwsooner6
2008 KK Liberty
Originally Posted by lfhoward View Post
The jack is still there. I used a smaller inverter so it would fit in the space:
And the power supply taps into the line powering the trailer wiring harness:
Have any tips on finding the trailer wiring harness to tap into?
Mine did not have a tow package, do you think the wires will still be there?
bwsooner6 is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 01:35 PM   #63
_benjammin
2012 KK Liberty
The wiring harness plugs into the driver's side rear light and then the lights plug into the wiring harness.
Unread 11-05-2013, 06:16 PM   #64
bwsooner6
2008 KK Liberty
Thanks!
Blacked out
265/70R16 Terra Trac's
Headlight Mod
At The Helm Roof Rack & Front Recovery System
Unread 11-05-2013, 06:27 PM   #65
lfhoward
2008 KK Liberty
On mine there is a red power wire from the battery that feeds the sack of relays (for lack of a better description) on the trailer wiring harness. I spliced into that red wire for power, but I also added an inline fuse at the battery end for safety. Here is what the wiring harness looks like:
2008 Liberty Sport 4x4 Automatic
lfhoward is offline   Reply With Quote Quick reply to this message
Unread 11-05-2013, 06:35 PM   #66
bwsooner6
2008 KK Liberty
Am I missing something? Should have to fuse if the inverter has a fuse, right??
Blacked out
Headlight Mod
Unread 11-05-2013, 06:40 PM   #67
_benjammin
2012 KK Liberty
Is that with the Factory Tow Package? The OEM add on 7pin wiring harness has a blue wire to run to the battery but you don't need to hook it up unless you have a brake controller or want to have a hot pin. Running lights and brake lights work from the taillight housing pigtail.
Unread 11-05-2013, 07:37 PM   #68
lfhoward
2008 KK Liberty
bwsooner6: I guess I like to be careful. It's good to have the fuse as close to the battery as possible.
_benjammin: I have the OEM 4 pin wiring harness so a I guess my wire color is different. The PO put it in and there are some custom wiring connections, so maybe the red wire doesn't come standard?
Even so, it is easy to run a power wire back there from the front, going behind the plastic trim.
Unread 11-05-2013, 07:47 PM   #69
bwsooner6
2008 KK Liberty
bwsooner6: I guess I like to be careful. It's good to have the fuse as close to the battery as possible... Even so, it is easy to run a power wire back there from the front, going behind the plastic trim.
Good point, because of the amperage, I'll probably just run a new wire back
"if it's on the internet, it must be true" ~ Abraham Lincoln
Blacked out
Headlight Mod
Unread 11-06-2013, 07:04 PM   #70
lfhoward
2008 KK Liberty
Another little electrical mod:
http://www.lostjeeps.com/forum/phpBB...p?f=45&t=76635
Unread 11-07-2013, 02:14 PM   #71
shawnicles
2008 KK Liberty
You make me school girl jealous with your nifty ideas. My battery just died on the weekend because the lights were on when the back was open.
shawnicles is offline   Reply With Quote Quick reply to this message
Unread 11-08-2013, 07:09 PM   #72
MtnmedicKK
2011 KK Liberty
Slowly working on adding orange accents to my Green Renegade
MtnmedicKK is offline   Reply With Quote Quick reply to this message
Unread 11-08-2013, 08:06 PM   #73
musclezmarinara
2012 KK Liberty
Originally Posted by Gageraid View Post
My favorite exterior mods would be my Mopar light bar and plastidipped grille. Gives my Jeep a little personality.
That light bar though
2012 KK Cherokee * Arctic * Mineral Gray
- Mods - See Build Thread..
musclezmarinara is offline   Reply With Quote Quick reply to this message
Unread 11-08-2013, 08:16 PM   #74
shawnicles
2008 KK Liberty
I like it
Unread 11-08-2013, 08:31 PM   #75
LKWJEEPER
2009 KK Liberty
I like that idea adding the orange.
Sent from AutoGuide.com Free App
LKWJEEPER is offline   Reply With Quote Quick reply to this message
