PIAA Brackets - JeepForum.com
post #1 of 4 Old 02-08-2014, 02:08 PM Thread Starter
98ZJ SFD
2012 KK Liberty
PIAA Brackets
I just got my PIAA 520s and noticed a bracket wasn't included in order to mount it to my Mopar bar. Any tips on something I can get locally?
Also, regarding the wiring, the instructions say to tap into a wire so they only come on with my low beams. I don't want them on all the time with my lows. Will the lights still power up without that wire being connected?
Current
2012 KK Sport, Mopar skids, DuraTracs, Mopar Grille Guard
Previous
98 ZJ Laredo SE 4.0, 2" Skyjacker BB, JKS Quicker Discos, Goodyear Wrangler MT/Rs, K&N FIPK, Kolak cat & back exhaust, Westin Safari bar, KC lights
98ZJ SFD is offline
post #2 of 4 Old 02-25-2014, 07:24 AM
staubitzk
2011 KK Liberty
I found that any Offroad lighting brackets are hard to come by in the local market. Amazon usually has the best deals with super fast shipping. As far as the wiring goes, it is up to you how you want them to be powered.
You can either power them straight from the battery, or from either your low or high beams. The PIAA should of came with a relay. I have mine wired so when I activate my high beams, it gives power to my switch which turns on the lights. To do this, the switch "HOT" wire should be connected to the HOT from the high beams.
If you want to turn on your lights by just using the switch, then connect the "HOT" line from the switch to a always hot source such as the battery.
As a word of advice, If you are going to do an independant switch, I would suggest connecting the "Hot" line to an ignition source such as tapping into the cigarette "HOT" line underneath the climate controls. This is so if the car is off, it kills power to the lights. I cannot tell you how many times I killed by battery by accidentally leaving the lights on.
I also got tired of having to turn the switch on and off when I wanted to use the lights. It is so much more convenient to wire them to either the high or low beams. Below is a great link on which wire to tap into in the headlights:
http://connectors.dcctools.com/home....7CE5CD45FE4A5B
2011 Jeep Liberty Sport~OME Lift~ Tow Hooks ~ Skid Plates ~ Hitch ~ Built In Air Compressor ~ Black Rock 997s Steel Rims ~ Wrangler Duratracs ~ JK Front Mounted Lightbar ~ Tuff Stuff 22inch LED Bar ~
staubitzk is offline
post #3 of 4 Old 02-25-2014, 09:31 AM Thread Starter
98ZJ SFD
2012 KK Liberty
Thanks for your reply.
I went with the PIAA brackets from Amazon.
I wired the switch power to hot so I can turn the lights on whenever I feel like. I didn't want them on all the time with either my highs or my lows. But that's still great information which I may keep handy for future reference, in case I want to switch them to my high beams at some point.
I was concerned about the switch light being lit green all the time, but I can't imagine it draws much power.
Current
Previous
98ZJ SFD is offline
post #4 of 4 Old 02-26-2014, 08:50 AM
staubitzk
2011 KK Liberty
When you wire the switch to your high beams, the switch is only illuminated when you turn your high beams on. I put my rocker switch inside the center console so I never see it anyway.
