Passenger Tow Hook Installation - JeepForum.com
post #1 of 13 Old 08-02-2011, 09:07 PM Thread Starter
Poncherello
2010 KK Liberty
Good Day,
I was wondering if anyone had ever installed a "tow hook" on the passenger side of their Lib?
The "Stealership" parts department told me that Jeep only sells the passenger side aftermarket tow hook because the driver's side towhook is too difficult to install.
Well, I got news for him, it seems the driver side has more room under the spoiler then the passneger side. When I get underneath the Lib I fell like a monkey trying to jam the square through a circular hole.
Without ripping or cutting the bottom rectangle part of the front fender, has anyone been successful installing the tow hooks?
Thanks :]
Poncherello is offline
post #2 of 13 Old 08-03-2011, 12:43 PM
marlon_jbt
2010 KK Liberty
Get the hooks from a KJ. The kit contains both.
Red Jeep Club member # 264
marlon_jbt is offline
post #3 of 13 Old 08-03-2011, 01:21 PM
jonrjen
2011 KK Liberty
Both of them should be available. I have both of them on my 2011 front end as part of the skid plate pkg. But, I will be pulling them off to install the Blue Ox tow bar bracket.
"If you have a difficult job to do....Give it to a lazy man....He'll find the easy way to do it."
jonrjen is offline
post #4 of 13 Old 08-03-2011, 11:52 PM Thread Starter
Poncherello
2010 KK Liberty
I already purchased the one hook for the passenger side. Jonrjen do you have the grille fins right behind your tow hooks? In the picture it's roght where my hand is?
Does anyone know how to remove the bottom grille fins? The passenger side of the grille is not directly in front of the radiator I was thinking about cutting it off and reglueing it or just leaving it off.
If the whole bumper has to come off, I will purchase the other tow hook beofre I do all that.
Thanks!
post #5 of 13 Old 08-04-2011, 06:08 AM
jonrjen
2011 KK Liberty
Yes, mine has the lower panel you are speaking about. I just went out and took a look, and I don't see a way to remove the panel without removal of the front bumper cover. Not to say it can't be done, I just don't see how to do it.
I have to remove the entire bumper cover for my installation anyway, good luck.
Unless maybe you could get removed using a series of swivel joints attached to the socket and feeding an extension through a fin opening.
jonrjen is offline
post #6 of 13 Old 08-04-2011, 09:08 PM Thread Starter
Poncherello
2010 KK Liberty
Thanks for the update. I was crawling all underneath the Lib trying to get the tow hook from behind the grille and pull through the front. And it was just not happening forlike over an hour. I am a patient man but when the patience run, I start counting then, things begin to break LOL!
post #7 of 13 Old 12-28-2011, 09:18 AM
huntb
2008 KK Liberty
FYI there is no need to remove the bumper to install the tow hook... at least for the passenger side. I just did this last night.
huntb is offline
post #8 of 13 Old 12-28-2011, 11:54 AM
Bmxer524
2011 KK Liberty
I put a brush guard on that mounts to where the tow hooks go. Just cut the solid plastic off. You don't need it. I'm pretty sure older models don't even have that plastic grill there, let alone solid chunks of plastic where the tow hooks go.
And you shouldn't have to remove the bumper at all.
Bmxer524 is offline
post #9 of 13 Old 12-28-2011, 12:24 PM
huntb
2008 KK Liberty
You don't need to cut any plastic either. Just go from underneath the truck and you can access the holes that way
huntb is offline
post #10 of 13 Old 12-28-2011, 01:30 PM
Jeepin11
2011 KK Liberty
There is plastic panels that cover the opening where the hooks go on non oem equipped libs. There is three tabs that mount to the bumper that you need to cut to remove the plastic cover.
2011 KK- 265/75-16 Wrangler Authorities on 16x8 Racelin Assault wheels
Jeepin11 is offline
post #11 of 13 Old 12-28-2011, 01:49 PM
huntb
2008 KK Liberty
I just installed my tow hook last night and there was no cutting or removing of anything.
huntb is offline
post #12 of 13 Old 12-28-2011, 03:36 PM
Bmxer524
2011 KK Liberty
You have a '08, I have an '11. Like in the op's pic, there is that gray plastic grill. Near the edges, behind the hook in the picture, there is the sold pieces. You have to cut those out on the newer models. I don't believe 08s have that. Atleast every one of my friends' '08s dont.
Bmxer524 is offline
post #13 of 13 Old 12-28-2011, 03:49 PM
VegasDragger45
2010 KK Liberty
Like Bmxer524 said you just have to cut the three tabs holding that square grill in. I had to do this on my 2010 to get the hooks installed. Once you cut it out you can fish the hook in through the front and bolt it down. If you look it is connected on the left and right side as well as the bottom. Just cut those tabs with a knife and your ready for the tow hook. No need to remove the bumper or the insert.
2010 KK, 2" Daystar lift, 245/75/16 BFG All-Terrains, interior LED's, front rear and cargo liner weather tech's, Pioneer AVH-p4400BT, GEX-P920XM, Kicker 6" in front 5 1/4" in rear, PB 2.75" in dash, Kicker 300.1 amp, Pioneer TS-SWX310, JK light bar with Hella 500 ff and 100w bulb, BOYO rear view camera, JBA exhaust, K&N drop in filter and more to come.
VegasDragger45 is offline
Passenger Door CLUNK! 2008 furyphoto KK Liberty Forum 3 07-08-2011 06:05 AM
Skid plate/tow hook pkg jonrjen KK Liberty Forum 2 07-02-2011 08:54 PM
Power passenger seat? jonrjen KK Liberty Forum 2 07-01-2011 06:07 AM
Passenger Side Tow Hooks KISSlover101 KK Liberty Forum 2 04-27-2011 12:31 PM
Passenger Brake Light Out freebird KK Liberty Forum 1 11-01-2010 12:44 PM
