Passenger Side Brake Light Out - JeepForum.com
post #1 of 3 Old 09-08-2013, 09:15 PM Thread Starter
Wsmithers
Hi Forum Members,
I'm having an issue with my passenger side brake light. The running light works fine but when the brakes are applied, the bulb does not get brighter like it should. The driver side light and the third brake light are fine.
I'm guessing the issue is narrowed down to the brake light housing itself but what should I look for? Are there are common issues that cause this? If I need to test with a voltmeter, does anyone know what pins to check and what voltage?
Thanks for any suggestions
Wsmithers is offline
post #2 of 3 Old 09-08-2013, 09:32 PM
huntb
2008 KK Liberty
Try replacing the bulb first. Swap the left and right and see if the issue follows the bulb itself or if it is a connection issue
huntb is offline
post #3 of 3 Old 09-08-2013, 09:35 PM Thread Starter
Wsmithers
Sorry, I forgot to mention the first thing I did was change the bulb. I was debating to go back and get a different bulb or try swapping the one from the driver side. I'll try that first.
