Passenger Door CLUNK! 2008 - JeepForum.com
post #1 of 4 Old 07-05-2011, 09:54 PM Thread Starter
furyphoto
2008 KK Liberty
Recently, every time I close my passenger door there is a big CLUNK.
It looks like the bushing on the device that holds the door open has worn, and the lever part is moving too far and getting stuck. It makes the door hard to close and very annoying.
By the looks of it, everything is riveted or stamped in place, and the only solution will be to replace the entire top hinge on the door. (EDIT, my mistake , it's the bottom hinge)
Has anyone else had this problem?
Can I get the part anywhere other than a dealer?
Thanks,
Andy
furyphoto is offline
post #2 of 4 Old 07-06-2011, 10:04 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Can you post a pic and circle where the problem is?
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #3 of 4 Old 07-07-2011, 11:12 AM Thread Starter
furyphoto
2008 KK Liberty
Thanks, Here it the photo. as you can see, it looks like the bushing is worn, and the lever that holds the door open is moving too far. Just far enough that is is perfectly aligned to prevent the door from closing. You have to push VERY hard, and then the door clunks when the lever snaps back into place.
I have tried lubing it, but it does not seem to help.
everything seems to be riveted or pressed, so it looks like I will have to replace the entire hinge.
And, sorry, it's the lower hinge , not the upper one as I mentioned in the first post.
post #4 of 4 Old 07-08-2011, 05:05 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Mine just started doing the same thing i the same spot like 2 weeks ago. I put some grease on it and it worked for like 3 days then started clunking again
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
2008 Tweeters jeepfreak108989 KK Liberty Forum 3 07-10-2011 06:40 AM
2008 gascap... jelwell1982 KK Liberty Forum 19 06-10-2011 07:31 AM
Where to buy air filter replacement for 2008 KK? LibertyHopeful KK Liberty Forum 9 01-03-2011 08:46 PM
2008 KK Questions ChuckPink KK Liberty Forum 10 12-05-2010 11:37 AM
2008 KK lift? GilNewJeeper KK Liberty Forum 6 01-05-2010 08:19 PM
