Parking Brake adjustment '08 Liberty - JeepForum.com
 2Likes
post #1 of 24 Old 01-30-2009, 07:50 AM Thread Starter
08liberty
2008 KK Liberty
Can anyone tell me how to adjust the parking brake on my Liberty, It is a new leftover with only 200 miles on it and with the brake lever all the way up, the Jeep still rolls, which is a problem because I have the 6 spd manual. The simple solution would be to have a dealer do it, but if the adjustment is simple enough I would rather do it myself then drop it off with them. Mine has the disc brakes in the rear...Thanks!
08liberty is offline
post #2 of 24 Old 01-30-2009, 08:01 AM
BrendonR
http://gravediggerfreek.googlepages....yRecallH28.pdf
That'll show you how to do it. There was a Saftey Recall on these already - for any Liberty build before February 13, 2008 w/ manual tranny. Personally, as it's a safety issue - I'd have the dealer do it.
2008 Jeep Liberty Ltd.
Red Rock Crystal Pearl - Sky Slider
Current Mods: None
Currently accepting donations to remedy above.
BrendonR is offline
post #3 of 24 Old 01-30-2009, 12:09 PM
CmdrK
2008 KK Liberty
If you're within the date range, by all means have the recall done.
Mods include: full size spare, Mopar front tow hook. Mopar skid plates, rear recovery mount (trailer hitch with D-ring).
RED JEEP CLUB MEMBER #145
LIBERTY LOVIN CLUB MEMBER #4
CmdrK is offline
post #4 of 24 Old 01-31-2009, 01:59 PM
ErikRP
2017 WK
Does this mean that the brake is fine on the automatics, just not the manuals? Or that it shouldn't be an issue for those with automatic transmissions so don't worry about it?
2017 Grand Cherokee Summit - Granite Crystal Metallic
Yes, it's got a Hemi!
ErikRP is offline
post #5 of 24 Old 01-31-2009, 11:08 PM
jeepernj
2008 KK Liberty
I also have an 08 KK 6 spd manual. I had the same problem, the parking brake was almost useless. I just had the recall done at my dealer and it is 100% better. The brake is fully engaged after pulling it up about an inch or so. I would check with your dealer, it was definitely a safety issue...I could not park on a steep incline.
jeepernj is offline
post #6 of 24 Old 02-01-2009, 03:25 PM
diggerfreek
2008 KK Liberty
Since I posted this TSB, I have only heard of 1 or 2 autos with bad parking brakes... Now I could be wrong, but of you have a manual, get it done. If you have an auto with a POS parking brake, get the part number and see of the service writer you use will have the tech install that new part
diggerfreek is offline
post #7 of 24 Old 01-02-2010, 10:37 AM
COLORADO
I have an 08 Auto with a POS parking brake. Is there any way to adjust it without replacing the assembly
COLORADO is offline
post #8 of 24 Old 01-02-2010, 12:59 PM
Elt31987
Elt31987's Avatar
2008 KK Liberty
^^ Same here, mine sucks
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #9 of 24 Old 01-02-2010, 01:17 PM
diggerfreek
2008 KK Liberty
Recall done and mine blows.......
post #10 of 24 Old 01-04-2010, 07:59 PM
sbougon
2008 KK Liberty
Had the same problem. Had to replace the entire lever assembly. There is no external adjustment.
sbougon is offline
post #11 of 24 Old 01-04-2010, 08:23 PM
tjkj2002
2002 KJ Liberty
A $12 fix that will always work(sorry couldn't resist).
Rubber Wheel Chocks for Trucks and Trailers
tjkj2002 is offline
post #12 of 24 Old 02-01-2010, 01:18 PM
COLORADO
I pulled my rear wheels and the calipers. There is a rubber plug under the caliper which after removal allows adjustment of the shoes for the drum parking brakes. the adjustment procedure is the same as for any drum brake. Use a brake adjustment tool or a screwdriver to adjust the star. On mine there was no self adjusters so no worries there. Now did it work!, not very well. Before adjustment the E brake was useless, after adjustment the brake lever still comes up to the top but at least it now holds on a hill. It appears that the cables are a bit to long and so far I have not found a way to adjust the cable length. Good luck.
COLORADO is offline
post #13 of 24 Old 02-25-2010, 02:01 PM
COLORADO
After I did the adjustment I sent an EMAIL to jeep explaining my problem. I got an EMAIL response today and
while I was reading it I got a call from my dealer telling me to bring the liberty in right away. The checked out the parking brake system and confirmed it was not working properly and the problem was not due to adjustments. They have ordered a new assembly and will replace it under warranty as soon as they get it in.
Chrysler did not have the part available but they found one at a dealer in Tenn. I live in Colorado. I was pleasantly surprised at their response and that of my dealership. Congrats to Jeep
COLORADO is offline
post #14 of 24 Old 03-03-2010, 07:10 PM
COLORADO
Dealer replaced parking brake assembly under warranty. Works like a champ now.
COLORADO is offline
post #15 of 24 Old 03-15-2016, 08:55 AM
COLORADO
origonal hand brake didnt work adjustment no help. Dealer replaced handbrake assy worked for a couple of months then same failure. Not sure what to do nexk. I may try to put in sone kind of cable tightners.if I can find somethind that will work. 2008 automatic.
COLORADO is offline
2008 Liberty Headlight Adjustment sbougon KK Liberty Forum 10 12-03-2013 06:02 PM
snorkel for liberty kk david1980 KK Liberty Forum 6 05-03-2013 08:28 AM
Liberty Gas Mileage jeepkid60 KK Liberty Forum 63 11-29-2010 01:12 PM
15's on an 08 Liberty>?? CoachRamirez KK Liberty Forum 2 02-06-2010 10:28 AM
Liberty or Patriot better off road? diver110 KK Liberty Forum 4 12-17-2009 05:28 PM
