P 300 P303 P304 .. leaking down on coil pack? - JeepForum.com
post #1 of 11 Old 04-05-2011, 10:46 PM Thread Starter
thadoc8113
2003 KK Liberty
Im no mechanic, but i am able to fix most things. Just not familar with engine wrk. Heres my dilema. My engine light came on says misfire in 3 and 4. I was leaking coolant from overflow but was sure i fixed it. Anyways could a leak above the engine cause it to misfire like that. I had mechanic rip it down and replace head gasket.. said he had heads checked but starting to think he lied. Any known problems with this? It is a Jeep liberty 3.7 4 x4 , which i was sure someone told me was the same a s a kj. Any help would be appreciated. Just dont have any more money to put into. ... I did lose water pump at that time drove for no more than 4 miles, let it cool. Replaced water pump. Drove it for about three months with no problems, coolant loss or anything. Then out of the blue...sorry this is a little backwards.
thadoc8113 is offline
post #2 of 11 Old 04-05-2011, 10:55 PM
CherokeeGT
i would say that because youve got missfires on both banks of the engine that your gonna find that your problem is not something like coolant dripping on your coil packs,
i would pull coils 3 and 4 and switch them with coils 5 and 6
if your codes changes to p0305 and p0306 then you know youve got 2 bad coils
if they dont change then try the same thing with the injectors
(the coils are the most common cause of a missfire code.... and usually as a resuly of an oil leak in the valve cover to the plug)
i hope you get er figured out and if youve got any questions pm ill try my best to help ya out
CherokeeGT is offline
post #3 of 11 Old 04-05-2011, 11:13 PM Thread Starter
thadoc8113
2003 KK Liberty
ok will do tmrw.. will i have to unhook battery to get codes again or should it switch when i start er up?
post #4 of 11 Old 04-05-2011, 11:15 PM Thread Starter
thadoc8113
2003 KK Liberty
also engine light was flashing for a bout a mile or so, got it home and shut it off, im thinking heads are warped since exhaust was billowing out smoke. Ill try wat u said first.
post #5 of 11 Old 04-07-2011, 12:07 AM
CherokeeGT
you shouldnt have to worry about clearing codes... your just looking for new codes
also if you have a missfire your check engine light will flash to warn you that you could be damaging your cat
a missfire causes alot more unburnt fuel to enter the cat too much fuel burning in the cat will melt it
post #6 of 11 Old 04-07-2011, 05:12 PM Thread Starter
thadoc8113
2003 KK Liberty
ya i took overflow tank off was leaking on coil packs on pass isde. Two odf the three werer wet from coolant getting down in there. I hope that is all it is. Also noticed one brether line i think its called was off and cut on the end. Gonna replace both and go from there.Is it possible that that could cause misfire.
post #7 of 11 Old 04-07-2011, 07:48 PM
CherokeeGT
if the coolant was on the coil it definately could have caused the missfire
pull your coils out clean them with brake clean so there nice and dry then put dielectric grease around all the connectors and the plug boot that should keep moisture out and your connections clean
AND FIX THAT COOLANT LEAK \\ hehe
post #8 of 11 Old 04-07-2011, 08:43 PM Thread Starter
thadoc8113
2003 KK Liberty
ya i started doin that .. but probably a stuipid question. If some coolant got down into the cylinders .. do i have to get it out somehow, i was thinking a bulb syringue. Or can i just let it dry out Thanks for your time!
post #9 of 11 Old 04-07-2011, 08:51 PM Thread Starter
thadoc8113
2003 KK Liberty
another thing misfires said all on passenger side checked driverside middle plug which i believe is the no 4, and this was dry. Is it possible it just through wrong code since 2 of three on pass side were getting coolant in them.
post #10 of 11 Old 04-09-2011, 07:19 PM
CherokeeGT
ok about getting some coolant into your cylinder while the plug was out... just leave the plug out and turn the engine over thatll get rid of it.
iam not shure which bank is which on your engine but youll generally have one bank is odd numbers and one bank is even numbers (some companies dont identify them that way however)... usually your most forward bank of cylinders is bank 1 bank one is your odd numbered pistons (again some companies identify there cylinders differently)
hope this helps
haha if you cant figure it out try and sink the "maid of the mist" with it!
post #11 of 11 Old 04-18-2011, 04:55 PM Thread Starter
thadoc8113
2003 KK Liberty
hey finally got the overflow tank installed ready to go, charged the battery up etc. got to hooking up oil fill line and noticed a creamy white substance in filler, and also in line going to back of intake. Like i said not familar with the technical terms. Is this normal or could it b just condensation as temp. here has dropped 20 degrees since i first took everything aprt. Do i need to drain the oil to make sure there isnt coolant in it. I did check the dipstick, and it looked great. Thanks again for your time.
00 XJ Misfire and diagnostics say coil fire malfunction, replaced coil pack XJAbuzer XJ Cherokee Technical Forum 3 02-03-2011 11:16 PM
bad coil pack? Travis873o ZJ Grand Cherokee Forum 2 09-08-2009 12:10 PM
Where Can I Get A Coil Pack From? OLDoRedoWolf XJ/MJ Cherokee Non-Technical Forum 6 02-15-2009 01:50 PM
Prob W / Coil wire/Coil pack & Steering Colum dcomb Jeep CJ Forum 5 08-23-2007 02:28 PM
coil pack marley66 Audio, CB & Ham Radios, GPS, & Electrical 2 07-11-2006 02:12 PM
