Ome hd installed.. - JeepForum.com
post #1 of 14 Old 02-16-2013, 03:17 PM Thread Starter
Aryzurak
2009 KK Liberty
Ome hd installed..
So I replaced shocks and springs with ome hd. I also added 2 conduit nuts in the front thinking it ll be a leveling the lift. It rides and handles great. But my issue is the front sits one inch higher than the back! Will it settle and level itself?
Aryzurak is offline
post #2 of 14 Old 02-16-2013, 03:24 PM
Jeffro06
Jeffro06's Avatar
Conduit nuts?
Jeffro06 is offline
post #3 of 14 Old 02-16-2013, 03:35 PM Thread Starter
Aryzurak
2009 KK Liberty
Yes its a trick i learned here. 2" diameter electrical conduit nuts. I stacked 2 adding up to 1/4 inch which gives me a total of 1/2 inch lift. Most people go with 3.
Aryzurak is offline
post #4 of 14 Old 02-16-2013, 03:42 PM
AtTheHelm
The front should settle some after a day or two.
Rear add two (per side) spring isolators and it'll boost it up a little.
AtTheHelm is offline
post #5 of 14 Old 02-16-2013, 03:50 PM Thread Starter
Aryzurak
2009 KK Liberty
Thanks, I always thought the rear was going to be higher because people talk about putting 3 nuts and top spacers. I will add the rear isolators and go from there.
Aryzurak is offline
post #6 of 14 Old 02-16-2013, 03:59 PM
mtbiker
2011 KK Liberty
Just ordered the OME HD for my '11. If I install just the springs I will retain the factory rake? Looking to keep the back a little higher so its level when loaded down. I tend to carry a good bit of gear in the Spring-Fall.
mtbiker is offline
post #7 of 14 Old 02-16-2013, 04:16 PM Thread Starter
Aryzurak
2009 KK Liberty
I think it will be a little higher in the front. You can always stack some rear spring isolators they'll give you about 3/8 a piece, thats what I'm gonna have to do looks like.
The good thing with the hd is you won't be sagging as much with heavy load.
Aryzurak is offline
post #8 of 14 Old 02-16-2013, 06:35 PM
teckn9ne
2010 KK Liberty
My front settled very fast got my rake back day after install i just installed hd shocks and springs no clevis etc but have every skid plate including front radiator so my front heavier then rear very very happy with ride and lift.
2010 Jeep Liberty Sport 4X4 Natural Green Pearl
Silverstar Headlights,Mopar Hitch,Mopar Tow Hook,Mopar Skids,Mopar Locking Lugs,Mopar Remote Start,Factory Sirius Radio,WeatherTech Digital Floor Mats,JCROffroad Stage 3 Sliders,Hankook DynaPro RF10 LT225/75/16,Diehard Platinum P1,JBA 5.5 UCA,OME HD,
teckn9ne is offline
post #9 of 14 Old 02-16-2013, 06:53 PM
mtbiker
2011 KK Liberty
Did you do the a-arms too? Or just the springs/struts & shocks?
mtbiker is offline
post #10 of 14 Old 02-16-2013, 07:11 PM
teckn9ne
2010 KK Liberty
I did the jba uca it helped alignment alot and the quality is best on market.My stock arms had losest balljoint iv ever seen also only 38k miles
teckn9ne is offline
post #11 of 14 Old 02-16-2013, 07:39 PM Thread Starter
Aryzurak
2009 KK Liberty
I didnt do the arms, but i can tell they are nit happy I heard you dont need them if going arround 3 inches.
Aryzurak is offline
post #12 of 14 Old 02-16-2013, 08:25 PM
teckn9ne
2010 KK Liberty
It took alittle time geting alignment just right with the jba we did get it but my caster is off still off a tad but i no next alignment il get it probaly be dead on.Best investment iv put on is the lift and arm rides 10000 times better and jba balljoint replacement is less work and down time .I myself wouldnt keep the oem arms but alot do use and i wont knock if it works for them.I just decided might as will do it all at the same time and it was the right decision for me cause i didnt want any oem uca alignment problems or replacement in near future.
teckn9ne is offline
post #13 of 14 Old 02-18-2013, 05:15 PM
TurboGoKart
Usually, if you have a rake pre-lift, you'll have a rake post lift. I did the 3 nuts in the front plus 1/4" top spacers, and 2 extra (for a total of 3 per side) isolators in the rear and without it weighted down, the wheel gap is pretty darn equal.
TurboGoKart is offline
post #14 of 14 Old 02-18-2013, 05:36 PM
teckn9ne
2010 KK Liberty
My rake is minor 20" up front 20 1/2" back came fron 18" front 19" rear so its alot more level then it was.And got rid of the whip effect in the front when braking.
teckn9ne is offline
