OME 3 Inch Lift Questions - JeepForum.com
post #1 of 11 Old 07-09-2013, 10:04 AM Thread Starter
staubitzk
2011 KK Liberty
I am sure there are a ton of threads on the Old Man Emu lift kit as it seems to be one of the most popular. I recently ordered the kit from Jeepinbyal.com. I also ordered the extended rear bump stops.
http://jeepinbyal.com/jeep-liberty-2...ft-kit-kk.html
I was wondering If I needed to purchase anything else before I install. Want to make sure I have everything before I tear apart the Jeep. Also, are there any good walkthroughs or a how-to install so I can use as a guide? I will be posting pictures here of the process as soon as I start.
Picture before lift.
2011 Jeep Liberty Sport~OME Lift~ Tow Hooks ~ Skid Plates ~ Hitch ~ Built In Air Compressor ~ Black Rock 997s Steel Rims ~ Wrangler Duratracs ~ JK Front Mounted Lightbar ~ Tuff Stuff 22inch LED Bar ~
staubitzk is offline
post #2 of 11 Old 07-09-2013, 11:18 AM
AtTheHelm
You'll need the extended front bumpstops too. In the tech section on lost keeps theres a good write up for a jba lift, same procedure as ome.
AtTheHelm is offline
post #3 of 11 Old 07-09-2013, 11:35 AM
AtTheHelm
post #4 of 11 Old 07-09-2013, 11:43 AM Thread Starter
staubitzk
2011 KK Liberty
Thank you!! Will post pictures soon!
post #5 of 11 Old 07-09-2013, 02:28 PM
shawnicles
I don't think it's a requirement but adding the JBA upper control arm's made a huge difference in the front of the vehicle. The dealership when I went to re-align the vehicle after putting them in said he was surprised with how much of a difference they made the front of the vehicle sit
shawnicles is offline
post #6 of 11 Old 07-10-2013, 04:04 PM Thread Starter
staubitzk
2011 KK Liberty
Also is it a good idea to add coil isolators to the setup?
post #7 of 11 Old 07-10-2013, 07:19 PM
carlosburitica
2010 KK Liberty
yes. I didn't install mine in the beginng and has to be done. if you add a Clevis lift in the front you knee extra issue on the back to level up
carlosburitica is offline
post #8 of 11 Old 10-14-2013, 05:34 PM
nfodzy
2011 JK Wrangler
Hey staubitzk, what site did you get the JK light bar from? Was it hard customizing it to fit on the bumper? What exactly did you have to do?
nfodzy is offline
post #9 of 11 Old 10-14-2013, 11:16 PM
khalilw
2011 KK Liberty
http://www.lostjeeps.com/forum/phpBB...?f=104&t=74082
khalilw is offline
post #10 of 11 Old 10-16-2013, 04:02 PM
nfodzy
2011 JK Wrangler
thanks! did you post a pic of your kk with the ome lift?
2011 JKU - 1" Bodylift + 2.5" Suspension - 295/70r17 Cooper Discoverer Pro on Pro Comp La Paz
nfodzy is offline
post #11 of 11 Old 10-16-2013, 05:38 PM
khalilw
2011 KK Liberty
No, My KK isn't lifted
But I have 2 Hella rallye 4000 on the light bar (because I relocated the tabs to the front of the lightbar so this big hellas can fit)
khalilw is offline
