OME on 225/75E16's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > OME on 225/75E16's
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 04-22-2013, 08:16 AM   #1
rescue575
2011 KK Liberty
OME on 225/75E16's
Anyone running the OME on these tires? Would like to see some pictures if you have.
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 11:55 AM   #2
_benjammin
2012 KK Liberty
Not exactly what you asked for but pretty sure the look will be about the same.
JBA 2.5 with 235/70/16 (calculates to 29 inches versus 225/75=29.3 inches)
Sitting at 21.5 inches from center of wheel to bottom of fender lip.
_benjammin is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 12:20 PM   #3
rescue575
2011 KK Liberty
Awesome thank you. I would deff prefer a larger tire but that makes me more at ease that the dunlop fierce in the stock 225 will not look ridiculous under the lift.
2011 Liberty Sport
Unread 04-22-2013, 12:31 PM   #4
_benjammin
2012 KK Liberty
I was worried about those tires looking silly too. I needed a lift to keep the cross members from dragging on the beach. Even with bigger tires and pounding the pinch weld I would not have gotten the same amount of lift.
I really want bigger tires now but with only 9k on the original tires I can't justify the cost of new ones, even if I could sell the ones I got now.
Unread 04-22-2013, 12:40 PM   #5
mtbiker
2011 KK Liberty
Benjamin
Is that just springs in the front or is there conduit nuts/ Clevis also? Is the rear just OME springs? I am trying to keep the factory rake when I install my OME HD stuff.
mtbiker is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 01:05 PM   #6
_benjammin
2012 KK Liberty
mtbiker,
The JBA front is an adjustable coil over strut, no clevis lift. The adjust-a-strut can be raised even higher but others have said higher than 21.5 inches will wear out the CVs, and result in a backward rake with the rear setup.
The rears are Bilstein shocks, not sure about the springs,I think JBA had them made.
