Ok, stupid question time again.... - JeepForum.com
post #1 of 24 Old 12-06-2012, 08:24 AM Thread Starter
rescue575
2011 KK Liberty
Pretty sure I know the answer to this but figured I would put it out there. I know that the stock Sport had the option for either the 245/75/R16 or the 235/70/R16 (which to my understanding is the same size tire but just a little wider.
I am starting to shop around for tires since the high quality Goodyear's it came with are past 50% tread. I really like the BF Goodrich All Terrain T/A's. I had them on my Bronco years ago and really like the quality and look of them.
I have been researching them trying to get some prices. When I search for tires on any of the tire dealers using my KK as a starting point it does not show these tires as being available to put on the truck. Instead it shows the BF Rugged Trails. However, when I search by size (235/70/R16), the All Terrains show up. Now my guess is that this maybe because of the design of this tire that there would be some kind of rubbing as opposed to a more "radial" style tire.
Now secondly, if this is the case, I am planning on installing the OME Suspension lift kit ...guess it is like 1.5".(btw....will have many more questions on this.....). If this tire would cause rubbing of stock suspension, would this lift eliminate that???
Thanks to all in advance!!
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #2 of 24 Old 12-06-2012, 08:53 AM
tjkj2002
2002 KJ Liberty
The 245/75R16's are not a stock KK tire size,they are like 1.5" taller then the stock sized 235/70R16's.
235/70R16's = 29" tall
245/75R16's = 30.5" tall
tjkj2002 is offline
post #3 of 24 Old 12-06-2012, 09:05 AM Thread Starter
rescue575
2011 KK Liberty
That's my typo error...I meant stock with 225/75R16 and optional 235/70R16
2011 Liberty Sport
post #4 of 24 Old 12-06-2012, 09:10 AM
Wearyman
2008 KK Liberty
Ok,
First of all, always search by the size you want. if you search by your vehicle, you will get the stock tire sizes, and maybe some slightly larger ones that will also fit. you won't get anything that only fits with a lift.
This also explains why the 245/75/16's don't show up. Simply put, they will NOT fit on the Liberty without a lift kit installed. there is another thread here where someone put a chart up that shows the tire sizes and how they fit. Here is a quick rundown:
225/75/16 - Stock size
235/70/16 - Stock size
235/75/16 - Fits without a lift kit.
245/70/16 - Fits without a lift kit, rubs at full lock.
245/75/16 - Barely fits, rubs at lock and under compression. Needs minimum 1.5" lift kit to fit without rub.
Anything bigger - Get a lift kit or don't bother.
Wearyman is offline
post #5 of 24 Old 12-06-2012, 11:28 AM Thread Starter
rescue575
2011 KK Liberty
Right...exactly, but the 235/70r16 is a stock size which the bf comes in but doesn't show under a search. My question is will it fit without rubbing.
2011 Liberty Sport
post #6 of 24 Old 12-06-2012, 12:56 PM
tjkj2002
2002 KJ Liberty
If it's a stock sized tire offered on your KK it will fit with zero rubbing issues on the stock rims.
tjkj2002 is offline
post #7 of 24 Old 12-06-2012, 01:05 PM Thread Starter
rescue575
2011 KK Liberty
Originally Posted by Wearyman View Post
Ok,
OK, so i appoligize for my ignorance but......now the 245/75/16...would that fit on stock rim or would that require a different size rim? Also, for those who are familiar with it, would this size tire work with the OME suspension kit?
2011 Liberty Sport
post #8 of 24 Old 12-06-2012, 01:09 PM
Bmxer524
2011 KK Liberty
As long as you have a 16" rim it'll fit. And yes 245/75 16 will fit with the ome lift. It's actually 1 of the most common combinations between lift and tire size
Bmxer524 is offline
post #9 of 24 Old 12-06-2012, 01:13 PM
tjkj2002
2002 KJ Liberty
245/75R16 tires work best on a 16x7 rim(stock rims size).Many like to put them on a 8" wide rim but that is at the very edge of that tire size rim selection.If you ever take it offroad and airdown more issues will result from having them on a 8" rim compared to a 7" rim.
tjkj2002 is offline
post #10 of 24 Old 12-06-2012, 01:24 PM
DeltaForceB85
2011 KK Liberty
Ill add a stupid question, what's the minimum lift I'd need to run 33s on my 08KK.
-Josh
DeltaForceB85 is offline
post #11 of 24 Old 12-06-2012, 01:43 PM
Bmxer524
2011 KK Liberty
Atleast 4+" and a lot of body modifications lol. Tjkj probably knows better details
Bmxer524 is offline
post #12 of 24 Old 12-06-2012, 02:23 PM
tjkj2002
2002 KJ Liberty
With no rub? At least 5" of lift with massive cutting,of course regearing is mandatory at that point to 4.56's.
tjkj2002 is offline
post #13 of 24 Old 12-06-2012, 02:47 PM Thread Starter
rescue575
2011 KK Liberty
Probably a bit of a long shot for a specific request....does anybody have the OME suspension lift (please specify which one) and running 245/75R16 tire? Can you please post a picture....I would really like a visual of how it will look before I she'll out the cash!!!!!
2011 Liberty Sport
post #14 of 24 Old 12-06-2012, 04:13 PM
Bmxer524
2011 KK Liberty
Check out some of the posts on LOST. I recently asked a member to post a side view of his KK to see if I wanted to get the spacer plates along with the lift or not.
In the mean time, I'll see if I can get a few links for you.
Bmxer524 is offline
post #15 of 24 Old 12-06-2012, 04:24 PM Thread Starter
rescue575
2011 KK Liberty
Will definitely check overthere. Thanks for the efforts.
2011 Liberty Sport
