OK Need HELP! Bought 255/70/16 they do rub! - JeepForum.com
post #1 of 11 Old 05-29-2013, 06:06 PM Thread Starter
SarOpsSix
2011 KK Liberty
Well after long debating and people say no and people say yeah. I went with 255/70/16 on a 16x8 rim with a 5 inch BS. They do rub at full choke. I dont want to tear the inside of my tire well up. Anything I can do? Will spacers help or do i need a lift and what kind. Any info would be great i really dont want to sell these and go with a 245. I like they way they look. At this point i'm afraid even bumps will cause damage so looking to do this quick i cant be dropping 700 dollars. Thanks
SarOpsSix is offline
post #2 of 11 Old 05-29-2013, 06:15 PM
AtTheHelm
Wheel spacers will likely make it worse. I actually have a daystar 2" spacer lift for sale @ $100 plus shipping. Pretty sure they won't rub but can't guarantee it.
AtTheHelm is offline
post #3 of 11 Old 05-29-2013, 06:20 PM Thread Starter
SarOpsSix
2011 KK Liberty
What year is this for? And those are only for the front correct not rear too?
post #4 of 11 Old 05-29-2013, 07:42 PM
AtTheHelm
Front and rear for 08-12
post #5 of 11 Old 05-29-2013, 08:50 PM
huntb
2008 KK Liberty
Dude you have to be kidding me. I told you in that PM that 255/70R16 will rub. Why did you even ask me if you weren't going to listen?
Cut the wheel well till you can afford a lift and keep it on the road or at least buy Atthehelms spacers...
huntb is offline
post #6 of 11 Old 05-29-2013, 09:24 PM
tjkj2002
2002 KJ Liberty
It's your rims that are the cause of the rub.Go back to the stock rims(16x7) and you will not rub anymore.
tjkj2002 is offline
post #7 of 11 Old 05-30-2013, 04:15 AM Thread Starter
SarOpsSix
2011 KK Liberty
The reason being.. I had 3 people say they had no issues.
post #8 of 11 Old 05-30-2013, 04:18 AM
tommudd
2004 KJ Liberty
Some have no common sense and will tell you anything
Wheels are too wide as tjkj mentioned for one
tires are too big for two
Going to have to breakdown and lift it
of course going to a spacer lift it may still rub some with the wheel choice and then in no time you'll have to lift it properly anyways
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #9 of 11 Old 05-30-2013, 04:22 AM Thread Starter
SarOpsSix
2011 KK Liberty
will a daystar 2 inch lift work ? What else will i need to do if I put those on. Then will these tires look smaller now with this lift? I was trying to get a beefer look
post #10 of 11 Old 05-30-2013, 06:43 AM
tjkj2002
2002 KJ Liberty
It's your rims,if you don't want to lift you have to go back to rims with the stock width and backspacing or you must lift it and then yes the tires will look small as there really no bigger then 245/70's(a few mm's taller is all but about 3/8" wider).
But you most likely will nbot listen since you did not listen the 1st time doubt you will now.
tjkj2002 is offline
post #11 of 11 Old 05-30-2013, 06:59 AM
huntb
2008 KK Liberty
You could trying doing a clevis lift and see if that helps at all. Its very cheap and easy to do yourself, but like I said before, make sure you keep it on pavement
huntb is offline
