Oil Leak? - Page 8 - JeepForum.com
post #106 of 127 Old 12-07-2012, 08:54 PM
Poncherello
2010 KK Liberty
My rear seal went twice, the dealership said they took pictures of everything and sent it to Chrysler. There only explanation was that they noticed a lot of sand around it. I tild them I do serf fish and drive it on the beach hence its wy I bought a Jeep. Any Mark good luck and keep us posted.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #107 of 127 Old 12-08-2012, 10:57 AM
Skipper6413
2011 KK Liberty
I know there are different filters from my 2005 kj to my 2011 kk. I thought that was odd.
Skipper6413 is offline
post #108 of 127 Old 12-09-2012, 01:05 PM
rescue575
2011 KK Liberty
Mine is going in this week for rear main seal and front differential leaks. My buddy is svc mgr at the dealership so I asked him to go through everything to make sure I'm not missing anything.
2011 Liberty Sport
2 KC Slimlite[RIGHT] 130 Watt Long Range on JK Bar
TMS Aluminum Roof Rack Cross Bars
Cobra 75, Firestik Door Jam Mount, HD Spring, 2Ft Firestik
Dunlop Fierce Attitude M/T
rescue575 is offline
post #109 of 127 Old 09-29-2013, 10:35 AM
LibertyJ
2014 WK
Oil Leak
Hi all....appreciate all this info. I own a 2009 Liberty with 70,000k (43,000m). Last oil change noticed an oil spot on my driveway. Took it back to dealer, faulty oil filter replaced. Now again I noticed another spot on the driveway. Looked underneath to see oil which appears to be dripping at the front of the oil pan next to the water pump? Anyways it sure seems to me that this is why Chrysler discontinued the Liberty line as this appears to be faulty engine design. Will look to move on to another vehicle. Thanks again......have a great day!
LibertyJ is offline
post #110 of 127 Old 09-29-2013, 01:04 PM
Skipper6413
2011 KK Liberty
Did you clean it up from the faulty filter? Maybe residue drips? Main seal leaks aren't common as far as I know.
post #111 of 127 Old 09-30-2013, 05:48 PM
rescue575
2011 KK Liberty
x2. My friend who is service manager at a jeep dealership said same thing about main seal when I was having major dripping issue. Many times, oil filter is not tightened enough causing the drip. When I brought mine in they did the best they could to clean up what was done, but still had drips for a little while.
2011 Liberty Sport
post #112 of 127 Old 10-01-2013, 07:48 AM
rangerr47
2012 KK Liberty
I noticed a spot on the driveway the other day and got all worried, I could see it was dripping right in the middle, jammed my arm up in there and was able to just tighten the filter, it was 5k miles since last change(just swapped to syn) and had finally worked loose just enough, was able to tighten a quarter of a turn or so and never dripped again. Its pretty hard to get your arm up in there and get a good grip to tighten it well.
rangerr47 is offline
post #113 of 127 Old 10-01-2013, 10:47 AM
markjrenna
Rear Main Seal - replaced twice
markjrenna is offline
post #114 of 127 Old 10-01-2013, 12:16 PM
heiliges
2012 KK Liberty
Yeah... took mine to the dealership twice for leaks after oil changes were done. The word from the service folks is that its a pain in the butt to get to and tightening it requires some effort. Now that I realize its a common issue I will just double check it every once in awhile and after every change.
heiliges is offline
post #115 of 127 Old 10-04-2013, 09:15 AM
Gageraid
2008 KK Liberty
That's pretty sad service techs said tightening requires some effort. It's really not that hard. A filter should not be on so tight anyways.
Gageraid is offline
post #116 of 127 Old 10-04-2013, 09:51 AM
heiliges
2012 KK Liberty
Agreed but the last guy said he used the filter tool to get it on good. I followed up the dept head and they say its a gasket problem with the ones that come with the filter kit from Jeep.
heiliges is offline
post #117 of 127 Old 10-04-2013, 10:17 AM
Gageraid
2008 KK Liberty
Lol a problem on Jeep's part with their own filter? I don't even recall which filter I use, but know it's nothing fancy. If ya do your own oil changes you can save a few bucks and get to know your Jeep a little better.
Gageraid is offline
post #118 of 127 Old 10-21-2013, 07:29 PM
OldManLiberty
2002 KJ Liberty
Oil Filter Leak
I came upon this thread after two recent oil leak incidents with my 2002 Liberty Limited. I have owned the vehicle since it was new in 2001. It has 155k and runs great.
Last year I noticed it was requiring a quart of oil between oil changes. Nothing unusual, I thought, for a vehicle with over 140k at the time. Then I noticed a spot on my garage floor. I took it back to the independent shop who has been doing my work for years, and they told me the oil filter was loose. Of course they apologized and I thought that was the end of it. Just this weekend I found a HUGE puddle of oil under the car in the garage. I assumed it had blown a seal somewhere, but when I took it to the shop again they said the filter was quite loose. They apologized and replaced the filter and the 2 quarts of oil it was missing.
After reading this post, is it possible that this filter is in such an awkward location that some technicians can't tighten it enough? It just seems weird that this is happening all of a sudden.
It's been 30 years since I changed my own oil, however I remember a key part of putting on a new filter required you to "seal" the new filter by rubbing a thin film of oil on the filter gasket. Is this still standard practice?
OldManLiberty is offline
post #119 of 127 Old 10-19-2014, 08:47 AM
LibertyJ
2014 WK
Hi all..... I continued to have my driveway show up with spots of oil. After many times going back to the dealer with no answer as to where it was coming from.....decided to upgrade and bought the 2014 GC Laredo. I figure if needing to pay for repairs on a older vehicle, might as well buy some thing new with warranty. Happy so far with the Laredo. 3989kms ....knock on wood!
LibertyJ is offline
post #120 of 127 Old 10-20-2014, 08:57 AM
markjrenna
I leased the Liberty. Other than the Oil Leak which was resolved the second time in the shop, I loved it! Lease was up and I picked up a GC too. Awesome vehicle!
Roof LEAK!! sunroof drain tube problems CoachRamirez KK Liberty Forum 63 06-20-2017 04:21 PM
2009 Rear Window Leak spolebitski KK Liberty Forum 46 11-06-2013 09:42 AM
Any thoughts on a fix for rear roof leak CoachRamirez KK Liberty Forum 7 12-06-2011 12:57 PM
2010 jeep liberty massive/severe ATF leak z0lt3c KK Liberty Forum 8 08-04-2010 02:31 PM
Cylinder Head leak afreseman KK Liberty Forum 9 08-02-2010 08:47 AM
