Oil filter - JeepForum.com
post #1 of 18 Old 03-03-2010, 03:56 PM Thread Starter
ARCHERYNGUNS
2011 KK Liberty
Oil filter
About to change the oil in my sister 08 KK. Anyone know the filter wrench size? This thing a pain to work on? Some cars can be annouying to get to the filter
ARCHERYNGUNS is offline
post #2 of 18 Old 04-02-2010, 09:21 AM
z06boy
z06boy's Avatar
2010 KK Liberty
Good question. I have a 2010 Liberty and "heard" the oil filter was a pain in the azz to get to...I haven't actually looked yet but am planning to change the oil over the weekend unless I get lazy and take it to the quicklube place.
Where is it located...way out front on the driver's side ? Thanks.
z06boy is offline
post #3 of 18 Old 04-02-2010, 06:42 PM
Seeks
2008 KK Liberty
Mine takes a 74 MM. Actually think I use a 74-76 combo I picked up at a local NAPA store. It's a little bit of a pain to get to the filter. Filter is on the front drivers side. 9-10 inch extension and a swivel joint of some kind. From just under the radiator shroud go up at a 45 degree angle through some hoses and you will get there!
Seeks is offline
post #4 of 18 Old 04-03-2010, 03:54 PM
Busch2fan
2008 KK Liberty
With a coupon from the dealer for $24 I get new filter and a 5 qts of blended sync oil. With the degree of difficulty in removing the filter it isn't worth it to me. I use to do the '03 Liberty and that was bad enough.
Now on the other hand my Dodge Ram truck is simple so I do it myself.
Busch2fan is offline
post #5 of 18 Old 04-05-2010, 06:13 PM
coder
2010 KK Liberty
I did the first oil change on my 2010 Liberty this past weekend. From underneath the filter was easy to get to and remove with a 70mm-76mm filter wretch.
I had a hard time finding the correct filter though. Most stores had the 08 filter, but 09-10 is different with a larger diameter hole (which I did not know) and had to go to 3 parts stores to find one.
Fram had what they claimed was the 2009-2010 filter but it was 1/2 the length of the OEM filter and I did not want to use it.
I finally found a Purolator filter PN# L22500, that looked correct, the store I was at only had 1 so I got lucky.
coder is offline
post #6 of 18 Old 04-13-2010, 11:28 AM
DanFxr
2010 KK Liberty
Oil filter
Last month I changed mine on a 2010 K.
I know the replacement for the 2010 was a Purolator 22500,I used a 14 flute 3 inch filter cap that I got at Auto Zone for 5 bucks.
To remove the mopar filter I used a 3 inch 15 flute that I already had in my garage,that original was on there tight! I didnot need an extension bar you can reach up and :feel : your way onto the filter.
DanFxr is offline
post #7 of 18 Old 04-16-2010, 01:46 PM
z06boy
z06boy's Avatar
2010 KK Liberty
Humm...didn't realize there was a difference either...good to know.
z06boy is offline
post #8 of 18 Old 09-14-2010, 10:12 AM
tr4petty
I just changed the oil for the first time on our 2010 Liberty. What a pain in the A _ _ to get to! Why would anyone design something that makes a routine maintenance item so hard to reach?!? Anyway, after several attempts with filter caps, filter wrench, etc. with no luck, I used a strap wrench that attaches to a 1/2 inch drive and with about 15" of extensions going fron under the radiator at about a 30 degree angle, I finally broke it loose. It was extremely tight but the oil drain plug was almost loose enough to turn it with my fingers!!!!!!
Go Figure! There's also no way to get the filter off without making a mess so you better just have plenty of rags around! Also, since the filter goes on at a steep angle, you can't really pre-load the filter with clean oil. Therefore, the engine runs dry for a few seconds. Mine made audible clicking noises for about 3 or 4 seconds, until the oil started circulating. Anybody else experience this? And another thing; any comments on the reason for using such a light (5w20) oil? That stuff poured like water! Seems awfully thin to me. Comments?
tr4petty is offline
post #9 of 18 Old 09-14-2010, 10:52 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
It is a pain, that's why i bring my oil and filter to the dealer and pay them 10 bucks to change it over. 10 bucks isn't worth my heartache . The reason such a light oil is used is because it gives your Jeep like .2 MPG more.
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #10 of 18 Old 09-14-2010, 11:02 AM
VMF
2008 KK Liberty
i use my bare hands and it works just fine kinda hard to get there with the wrench
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #11 of 18 Old 09-14-2010, 11:06 AM
VMF
2008 KK Liberty
oh and i only use mobil1 filter/oils
2004 UCF31. Black
VMF is offline
post #12 of 18 Old 09-14-2010, 11:08 AM
Elt31987
Elt31987's Avatar
2008 KK Liberty
Same here Mobil 1 5W20 and Mobil 1 Filter every 3K since first oil change.
2008 KK Liberty
Inferno Red
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline
post #13 of 18 Old 09-14-2010, 02:24 PM
VMF
2008 KK Liberty
i used to do it, but lately im starting to question the 3k oil change
here is a good article regarding the matter
Like the
2004 UCF31. Black
VMF is offline
post #14 of 18 Old 10-25-2010, 10:58 AM
mai-ling
2008 KK Liberty
We finally changed our oil yesterday.
Did the recommended 5W-20...
interesting comment from Elt31987 above on the .2 mpg more you get.
It was a bit of a contortionist act to get the filter off.
But I got it loosened by using a oil filter wrench.
It was pretty tight (maybe too tight) then my husband finished
the job by draining the oil pan and putting the new filter in.
Compared to my subie's it was a challenge but I'm glad we
can do it ourselves.
you will remember my name
World's Youngest Illusionista | 7th greatest pianist in the world | Go Red For Women and Stroke Ambassador
www.mai-ling.net
mai-ling is offline
post #15 of 18 Old 10-26-2010, 05:27 PM
SuperRliBerty
2008 KK Liberty
I use my hands and install a puralator pure one oil filter and 5 qts of pennzoil 5w20. I also put a "quick disconnect" on the battery terminal to reset the ECU at every oil change. I will post pics soon
2008 Sport Liberty
Cold air intake*Trush (magnaflow) turbo muffler* Hypertech power program*
Hood Prop mod. Battery Quick Release mod.
Resonator removed (sounds like a V8 on start up)
SuperRliBerty is offline
