off roading heat soak issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > off roading heat soak issue
The RuffStuff "I can't go to EJS" Sale!Offset Tie Rod Kit From RuffStuff!Check out our NEW Steering Stuff!
Unread 04-14-2014, 05:38 PM   #1
Reskar
2010 KK Liberty
So I went wheeling this weekend and twice when i shut off the truck and tried to turn it back on the computer was HOT. So hot it didn't let the truck start. Interestingly the temp gauage aways stayed right in the middle. Anyone run into this before? Suggestions? I wasn't running the AC I know that's bad.
Reskar is offline   Reply With Quote
Unread 04-14-2014, 08:41 PM   #2
Bmxer524
2011 KK Liberty
Never had that happen before. Where were you wheeling?
2011 Deep Cherry Red KK - Skyslider - OME 927/731 - Bilstein Shocks - 1/4" Spacer Plate - 3/8" Clevis - Al's A-arms - 245/75-16 Duratracs
Bmxer524 is offline   Reply With Quote
Unread 04-15-2014, 06:26 AM   #3
tommudd
2004 KJ Liberty
Remember that the temp gauge is an idiot gauge. It will stay in the middle until its way too hot almost.
A lot depends on where you were wheeling and also if using high or low range. Possibly you should of been using low instead of high range for example and over heated it that way ( transmission fluid getting too hot from slipping etc. )
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote
Unread 04-15-2014, 07:27 AM   #4
Reskar
2010 KK Liberty
was wheeling in south jersey pine barrens. I only turn on low range for hill climbs. I honestly wasn't wheeling all that hard but it was kind of hot out (high 70s) I wasn't even in 4wheel drive just cruzing along in 2wd for most of it. Also it's not like the engine block was cooking that was fine it was just the computer got SUPER hot. I know there is that fake vent there. I'm wondering if turning it into a real vent would help?
Unread 04-15-2014, 07:35 AM   #5
tjkj2002
2002 KJ Liberty
That would be your issue.I have never used 2wd or 4hi offroad,no point as I'd overheat pretty fast in high range but then again at 10,000' there is not much air to cool.
Over working the engine and trans creating a lot of heat that was at the max of your cooling system ability to maintain.
tjkj2002 is offline   Reply With Quote
Unread 04-15-2014, 08:36 AM   #6
tommudd
2004 KJ Liberty
^^^^^ yes
Unread 04-15-2014, 10:25 AM   #7
Bmxer524
2011 KK Liberty
Troy, depending on what trails you take a lot of the pine barrens are literally dirt roads. Some cars can even make it through a few of them...
Unread 04-15-2014, 10:30 AM   #8
tommudd
2004 KJ Liberty
But still slow going, driving slow, not moving fast enough to keep everything cooled down.
Unread 04-15-2014, 11:12 AM   #9
tjkj2002
2002 KJ Liberty
I still use 4low only on the "scenic" trails I've done here.Anything but a maintained gravel road or better I'm in 4low,gotta get my $2500 worth out of the Atlas!
Unread 04-16-2014, 08:19 AM   #10
Reskar
2010 KK Liberty
So I should always be offroading in 4 low and not worry about stress in the drivetrain?
Unread 04-16-2014, 07:20 PM   #11
tjkj2002
2002 KJ Liberty
Being in 4low is actually less stressful to the powertrain.Just keep the rpm's below 3500rpm's.
Unread Today, 06:40 AM   #12
Reskar
2010 KK Liberty
i guess i'm just confused as to all the opinions i've heard in the past about "only use 4wd if you have to" and so on. That because it locks front and rear together I shouldn't use it unless i'm on loose ground. Or does dirt roads count as loose ground?
