No heat-2009 liberty -help! - JeepForum.com
post #1 of 12 Old 10-13-2013, 08:56 PM Thread Starter
matthewz100
Folks,2009 jeep liberty
Had to turn on the heat this week for the first time this year and wonderful--no heat! blower fan works fine. reading up I see there are actuators that go bad? How many---electric? vacuum? Can anyone explain to me the heating components and their removal/troubleshooting process. I'll check to make sure heater hoses are both hot in the morning. thanks . bbbbrrrrr
matthewz100 is offline
post #2 of 12 Old 10-14-2013, 09:00 AM
carlosburitica
2010 KK Liberty
it happened to mine. i used my shop vac to blow air trought the vents and the actuator doors started to work again. change your cabin filter if you have one.
carlosburitica is offline
post #3 of 12 Old 10-16-2013, 05:36 AM Thread Starter
matthewz100
thanks--did you blow right into top vents or floor outlet? Where is actually the "mix" door located? thanks again.
post #4 of 12 Old 10-16-2013, 09:58 AM
carlosburitica
2010 KK Liberty
all vents, basically floor and front vents. hard to get to the top vents. did it wile switching to different positions
post #5 of 12 Old 10-22-2013, 11:00 AM
fireman_343
My wife's just did this too.. Heater hoses are hot to the touch, blows air, just isn't hot. I can hear the doors work when I switch from floor to vent, etc.. Also tried the turn to cold and then turn slowly to hot and no go..
Scheduled service at the dealer she got it from for Tues next week.. But, it's cold in the mornings so I might try the air trick or disconnect the battery to reset everything...
Anyone else have any ideas or have this problem
-Brian
97 TJ Sahara, 4.88's, 6" lift, 37" tires, flat fenders, etc...
fireman_343 is offline
post #6 of 12 Old 10-23-2013, 11:41 AM
Slayers
2008 KK Liberty
When you say the heater hoses are hot are you check the hoses going into the firewall?
Matthew there are a few pieces in the vent system that can go bad but they are not easy to work on.
You would have to take apart the hole dash just to start to work on the system and once you do that it opens up a hole can of worms.
Slayers is offline
post #7 of 12 Old 10-25-2013, 09:23 AM
fireman_343
Yes.. Both heater hoses going into the firewall are hot. I've tried everything.. Disconnect battery, blow air thru the vents, cycled knobs, check thermostat, still just cold air going thru all the vents.
I've scheduled a trip to the dealer since my wife has an extended warranty and I'll post up what they say. I'm thinking it's the heater core that went bad..
-Brian
post #8 of 12 Old 10-25-2013, 10:06 AM
carlosburitica
2010 KK Liberty
it is one of the actuators. mine got loose with the shop vac. and didn't get stock ever again.
post #9 of 12 Old 10-25-2013, 06:57 PM
fireman_343
Yeah.. I took my leaf blower to the vents and it still didn't work!! Ahhhh
-Brian
post #10 of 12 Old 10-27-2013, 08:50 AM
Poncherello
2010 KK Liberty
Same thing happened to me one of the actuators wasn't working right.
When you get knee-deep in a situation, floor it.
Poncherello is offline
post #11 of 12 Old 10-29-2013, 09:37 AM
fireman_343
Dealer said it was the heater core that's plugged up... $1100 to fix, but the damn core is only. $135
I think I'll try a flush first and if that doesn't work, I'll attempt the fix it myself due to the fact that it's going to be so much for them to pull the dash
Are there any how to pics on how to replace the core.. I'll do a search for it
-Brian
post #12 of 12 Old 11-03-2013, 07:03 AM
LUV4JEEP
Dealer said it was the heater core that's plugged up... $1100 to fix, but the damn core is only. $135 I think I'll try a flush first and if that doesn't work, I'll attempt the fix it myself due to the fact that it's going to be so much for them to pull the dash Are there any how to pics on how to replace the core.. I'll do a search for it
What was the finally result on this?? My heat has been acting up lately
LUV4JEEP is offline
