New-no nothing about jeep liberty limited 2008 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > New-no nothing about jeep liberty limited 2008
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 06-23-2013, 05:23 PM   #1
stewarg66
2008 KJ Liberty
Ok, I know nothing about cars, jeeps. My alarm goes off, wipers on, my washer to the windshields drain then the washer motor burned out. Wipers go on, lights flash. Now wipers have stopped working. Test light from pos. bat. term. to motor casing yields no light on tester. Test light from neg. to motor connector when run on, engine not running, wipers on at high yields no light on tester on.
What else can I do find out what is causing the wipers not to work ?
Thanks
G
stewarg66 is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 10:05 AM   #2
heiliges
2012 KK Liberty
fuse? Not sure if liberty has em but in the past I had a vw that had a relay switch that went out. i would imagine there is something similar that may have possibly blown.
heiliges is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 12:59 AM   #3
ASK87
2009 KK Liberty
make a good electrecian check your fuses panel and connections . a traditional multimeter would solve this issue .
ASK87 is offline   Reply With Quote Quick reply to this message
