New Jeep! Getting 9 mpg city - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KK Liberty Forum > New Jeep! Getting 9 mpg city
ZONE 4.25" combo lift for TJ available at Rockridge4wJeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinRIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 09-23-2014, 07:32 PM   #1
abbeymac
Hello All-
One week ago I purchased a 2008 Jeep Liberty Sport. 60k miles, 4x4, 4WD, 3.7 L and 6cyl.
I have been driving it in the city for the pass week, and filled up several times, each time keeping a record. After doing the math today I see that I am averaging 8-9mpg
I can literally watch the fuel gauge move down as I am driving. I am a conservative driver- I always keep rpms below 2.5, no harsh braking or accelerating.
I am nervous that I will not be able to afford the fuel this car eats, as I drive approximately 15-20 miles per day for work.
I bought the car used from a dealership, premium warranty.
Thanks!
abbeymac is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 07:41 PM   #2
lfhoward
2008 KK Liberty
Hi abbeymac, you and I are in the same town! I get 12 mpg city with a 4 inch lift and Goodyear Duratracs, so if your KK is stock, then there is definitely something going on. Do you know what maintenance was done prior to you buying it? I would suggest taking care of the easy things first.
1) Change the spark plugs (get regular NGK's or Champions, no platinums or iridiums because our engines don't like these).
2) Change the engine air filter.
3) It may be worth giving the throttle body a good wipe down as well if it is full of carbon.
4) If the oil hasn't been changed recently (it will look dark brown rather than golden if it is old), you should do that.
5) I'd also try running a bottle of fuel injector cleaner through with your next tank of gas.
I'm sure some other KK folks will chime in as well. You should be getting at least 14-15 mpg city with a stock Liberty, and up to 21-23 highway. Welcome to JeepForum!
2008 Liberty Sport 4x4 Automatic
lfhoward is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 07:55 PM   #3
NAMoulton
2010 KK Liberty
At 60,000mi a lot a maintenance was supposed to have been done. I noticed a 1-2mpg increase for the first few thousand miles after changing diff, transmission, and transfer case fluids/filters. Some dealers are cheap with their maintenance and try to sell at the mark to make you pay more for the needed maintenance.
Custom Bumper-JBA/Daystar Lift-16x8 M13 Rims-265/70 General Grabber AT2s-K&N CAI-Airaid TBS
NAMoulton is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 08:44 PM   #4
lfhoward
2008 KK Liberty
One other thought: Does it slow down pretty quickly when you coast? Or do you have a hot brake rotor after driving? A stuck brake caliper could also sap your mileage. But if you are still running the original spark plugs (which should be changed every 30,000 miles), that could also do it.
Unread 09-23-2014, 08:45 PM   #5
Gageraid
2008 KK Liberty
A 100% full tank and to empty is yielding 8-9 mpg? Something is wrong?
How many MILES to a tank are you getting?
Definitely change the plugs, oil, clean the throttle body, differential oils, transfer case fluid, and trans fluid.
I'd also get it scanned to see if it has any codes.
A stock KK should be getting 250-300 miles to a tank in the city.
OME lift
Hypertech Max Energy
CAI, Gibson exhaust, 4.7L throttle body
Gageraid is offline   Reply With Quote Quick reply to this message
Unread 09-23-2014, 10:55 PM   #6
Bmxer524
2011 KK Liberty
The worst I've ever gotten was 8mpg pure city in a blizzard(I had tcs off and was in rwd, I messed around that whole week also on 3.5" of lift with 245/75-16 duratracs). Stock I averaged 12-14. Closer to 12 in the winter.
Change your fluids, change the air filter, change your plugs. How often do you drive on the highway? Try getting on it a little. You gotta jump on it every now and then to blow the cobwebs out. Mine sees 4k+ rpm multiple times on a daily basis. Mine normally shifts into 2nd around 3-3500(just as you come into the power band)
2011 Deep Cherry Red KK - Skyslider - OME 927/731 - Bilstein Shocks - 1/4" Spacer Plate - 3/8" Clevis - Al's A-arms - 245/75-16 Duratracs
Bmxer524 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 08:05 AM   #7
abbeymac
Thank you all for your responses, now for my responses.
-Tires, new- FIRESTONE, I can get size when I run to lunch
-It slows down quite quickly when I take my foot off of the gas, does not have much coast in it (assuming flat land)
-My last tank was 170 miles, I am on track for 175 miles this tank
-I drove it on the highway over the weekend going about 75. 1.5 hours of driving put me at between 1/4 and 1/2 a tank (best gas mileage I have gotten)
Thanks!
Unread 09-24-2014, 07:31 PM   #8
brunolambert
2008 KK Liberty
9mpg sounds about right for winter city driving.
2008 KK Sport, Light Graystone Pearlcoat, Selec-Trac II, tow package, Firestone Destination LE2
brunolambert is offline   Reply With Quote Quick reply to this message
Unread 09-24-2014, 10:27 PM   #9
Gageraid
2008 KK Liberty
Thanks!
Something is not right here.
Are you stuck in 4wd or something?
OME lift
Unread 09-25-2014, 06:21 AM   #10
Ted15
Ted15's Avatar
2010 KK Liberty
I thought my 13 mpg was bad, and I'm not even close to stock anymore.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 11:02 AM   #11
Poncherello
2010 KK Liberty
Hard to tell about my mpg now running Bridgestone Revo2 265/70r16 my odometer and speedometer are off. Prior I was getting 16-17 mpg all around.
Hill ascent/descents, running the AC, goosing it at the lights and sudden stops.
Try using a different gas station when you fill reset trip meter.
When you get knee-deep in a situation, floor it.
Poncherello is offline   Reply With Quote Quick reply to this message
Unread 09-25-2014, 12:01 PM   #12
Bmxer524
2011 KK Liberty
Shouldn't be too far off. Probably about 4% or so, like my 245/75-16s.
Unread 09-27-2014, 07:16 AM   #13
Cleaner13
Thanks!
Im willing to bet you have a stuck caliper. It happen on my wife's KK around 65K miles or so.
There are different levels of it, but I was able to tell a few ways.
The first and easiest is to drive around approximately 5 miles or more and physically touch all your wheels. On ours the front passenger was very hot.
The other thing you can try to is put the jeep in neutral and try to push it, if you cannot move it, the caliper is stuck.
Above all else, I would also do as suggested from the others about all the maintenance. Its simple and cheap to do and atleast you know it was done and correct.
You dont have anything obvious like check engine light or a high idle(from vaccuum leak etc) right?
2001 WJ Limited NV247 4.7
2008 KK Limited MP1522 3.7
Cleaner13 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2014, 06:17 PM   #14
pinion
[QUOTE=Gageraid;25701154]A 100% full tank and to empty is yielding 8-9 mpg? Something is wrong?
I'll say..... but have you ever noticed, how many people do not know how to compute fuel mileage? It is amazing.
Then there are the trolls out here............
Why doesn't anybody talk about resetting the cpu by disconnecting the battery or changing the pcv valve?
Are you dividing miles traveled by the position of the gas tank gauge?
pinion is offline   Reply With Quote Quick reply to this message
Unread 09-29-2014, 03:58 AM   #15
josworth
2010 KK Liberty
Originally Posted by pinion View Post
Why doesn't anybody talk about resetting the cpu by disconnecting the battery or changing the pvc valve?
I'm pretty sure the OP is using either the miles traveled / gallons to fill or the EVIC calculated MPG. The internal MPG computer is pretty darn close. I tracked mine for two months and the computer was within 1% to 2% of the calculated number.
"pvc valve"???? I'm sure you meant the PCV (positive crankcase ventilation) valve. Not sure how that would drastically effect MPG considering there are actually two vents from the engine.. the PCV is routed to the intake and the secondary to the airbox. So, even if the PCV was stuck or clogged, excess pressure would be vented to the airbox. If it is stuck open you would just get a little more "oily air" into the intake... since the intake is a air inlet only, again that wouldn't effect that much. If it did, there was something very seriously wrong causing excessive crankcase pressure and oil loss.
Please enlighten the OP on how resetting the computer could bring MPG back to the 15 they should be seeing in mellow city driving.
Now, I'm not a troll, just jumping in before this goes off track. The first few posters suggesting plugs, a check of the 4wd, and the possibility of a dragging caliper were all sound suggestions therefore I haven't stepped in.
Personally, I think it is just in need of a tune up. Filter change and plugs.
Jeff
2010 Jeep Liberty Limited
josworth is offline   Reply With Quote Quick reply to this message
