New diff covers - JeepForum.com
post #1 of 17 Old 09-28-2013, 09:54 AM Thread Starter
BenHoleton
New diff covers
I need to change my differential fluid soon and figured I'd go ahead and get new differential covers at the same time. Any recommendations? I had Ruff Stuff Specialties on my old ZJ. They make them for the axles in the KK. But I don't know about the clearance issues. Any help would be appreciated.
BenHoleton is offline
post #2 of 17 Old 09-28-2013, 10:15 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
For the rear Chrysler 8.25 get a Solid Axle Industries cover. Don't think anything can be had for the front IFS set-up.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 17 Old 09-30-2013, 02:20 AM
Drednot
I got the PML and it hits the panhard rod. I like their stuff but you need to grind off two fins for clearance.
Basically that whole top fin has to go
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35@3.07
12 Cherokee 4x4,3.7L,42RLE/MP1522, D30M/8.25@3.73
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #4 of 17 Old 10-09-2013, 12:39 PM
Mattyvac
2012 KK Liberty
I just tried this, you can't put one on the front, and the rear has minimal clearance.
I just put my stock ones back on and said F it.
Mattyvac is offline
post #5 of 17 Old 10-09-2013, 12:57 PM
TIJKK1220
2008 KK Liberty
Search riddler differential covers. Diggerfreak has one and loves it
TIJKK1220 is offline
post #6 of 17 Old 10-09-2013, 01:29 PM Thread Starter
BenHoleton
I'll check out riddler. It seems the front one should be more important. You hit that first
post #7 of 17 Old 10-09-2013, 02:01 PM
Bmxer524
2011 KK Liberty
I don't think there are any for the front, besides it's kinda protected by the bracket. Take a look under the front end you'll see what I mean.
2011 KK - Skyslider - JBA Adjust-A-Strut - OME 731 - Bilstein Shocks - JBA UCA- 245/75-16 Duratracs
Bmxer524 is offline
post #8 of 17 Old 10-10-2013, 07:37 PM
Ted15
2010 KK Liberty
The front is stationary and the skid plate protects it. Also, the front cover is made pretty well. The aluminum is fairly thick and it has a drain plug. The rear however is stamped crap. I'd like to replace mine too.
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #9 of 17 Old 10-10-2013, 08:24 PM
tjkj2002
2002 KJ Liberty
X2 on Riddler,but for the rear as you can not use any aftermarket cover on your D30M.Plus being a KK is IFS no need for a beefier cover on a diff tucked up and out of harms way if you actually bought and installed the front skid plate.
tjkj2002 is offline
post #10 of 17 Old 10-11-2013, 11:48 AM Thread Starter
BenHoleton
No skids on my sport. It's on the list of things to do (will definitely be done before I hit any trails)
post #11 of 17 Old 10-12-2013, 12:30 PM
Ted15
2010 KK Liberty
I just had a good look at my front dif. It seems my memory was playing tricks on me, the front dif cover is stamped crap too.
Ted15 is offline
post #12 of 17 Old 10-15-2013, 02:08 AM
Drednot
You can't touch the front diff if you have the factory skid plates.
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
post #13 of 17 Old 10-15-2013, 02:21 AM
Bmxer524
2011 KK Liberty
Drednot, idk how you're KK managed to stay so clean underneath. I understand cleaning, but here on the East coast we get surface rust on anything that stays not painted almost over night. The humidity kills us!
Bmxer524 is offline
post #14 of 17 Old 10-15-2013, 04:50 AM
Ted15
2010 KK Liberty
The skids come right off. If you haven't had them off yet, it would be a good idea to remove them and put antisieze on the threads of the bolts. The threaded portion where the bolts go are nutserts and can cause real problems if they get stuck on the bolts.
Ted15 is offline
post #15 of 17 Old 10-18-2013, 03:40 AM
Drednot
Its Arizona...one of the reasons I moved here was to get away from the salt and humidity
Emission test=YES
"Non Vi Sed, Arte"
Drednot is offline
