My Review of the JBA 2.5 Lift with the tires i chose and Pic attached of my final Rig - JeepForum.com
post #1 of 6 Old 08-28-2010, 09:24 AM Thread Starter
bigworm36
2011 JK Wrangler
So I did know much about lifts when I first decided I want to lift my liberty. I spent alot of time on here reading other peoples reviews and researching about lifts and stuff. So i decided to go with the JBA 2.5 lift. I do not know much about cars but I would have to say the actual installation of the lift was fairly easy. Took me and my friend about 8 hours. I would have to say the hardest part of installing the lift was getting the ball joints loose, getting screws out and assembling the screws back in place. I did not know I was going to have to take the whole knuckle off on the front which took the most time. Installing the rear springs and shocks was very easy. The ride with the new lift is stiffer but thats what I expected. The instuctions were a little confusing at times but thats probably cause I was not familar with everything. Any ways I ended up going with 265/75/16 good year duratracs which is a great tire. There is not much noise at all from these tires and they ride great. I did have to pound in the pinch weld a little and do some fender trimming on the inside of the wheel well. There is still a little minor rubbing but instead of cutting the plastic I decided to just leave it since it was not a big deal. I ended up putting on Hoss XD 795 wheels (16x7) Anyways I hope this review helps anyone thinking about getting a lift. I super excited to try the new mods on the trails. Let me know what you guys think
1st- 1994 Jeep Cherokee
2nd-2000 Jeep Cherokee Sport
3rd- 2008 Jeep Liberty Unlimited 2.5 JBA Lift, 32" goodyear duratracs
Current- 2011 Rubicon Unlimited
bigworm36 is offline
post #2 of 6 Old 08-28-2010, 09:53 AM
MtnLuvr
2009 KK Liberty
Looks great and congrats. I've thoroughly enjoyed my JBA 2.5" lift for coming up on 1.5 years.
2009 KK Limited 4x4
Jeep Green/partially dechromed/Sunroof/OEM Skids/
Gray Leather/uConnect GPS-Nav/DVD Head Rests/
/JBA 4" AaS Lift w/UCAs/16x8's w/ 245/75R16 GY MT/Rs
MtnLuvr is offline
post #3 of 6 Old 08-30-2010, 12:40 PM
bigberto
2010 KK Liberty
same size lift/tires i just ordered, seeing a pic of yours makes me very happy, can't wait to get mine done...
the only thing dif, is my rim/wheel is 16x8
My Wheels/Rims chosen
ProCompTires PXA 7032 Flat Black
16 x 8, 5 on 4.5Bolt Pattern
* Backspace=4.5"
* Max Load =2200 Lbs
* Finish=Flat Black
* Hub Centric = NO
* Offset = 0mm
My Tire chosen:
DickCepek Radial F-C II Size: 265/75R16
Lift: 2.5 Daystar
the guy at "4 Wheel Parts" in Charlotte, NC told me this would fit, hope it does with little mods needed...
bigberto is offline
post #4 of 6 Old 08-30-2010, 08:54 PM Thread Starter
bigworm36
2011 JK Wrangler
* Backspace=4.5"
* Finish=Flat Black
* Hub Centric = NO
* Offset = 0mm
My Tire chosen:
Lift: 2.5 Daystar
Those rims and tires should look really good. I had to do some cutting of the inner plastic on both front wheel wells so there was no rubbing when I did a full U turn. I hammered the pinch weld in as much as possible but it was still very close to rubbing. I am taking it to the body shop tommorrow and they are going to grind the pinch welds flat and weld the area and then grind it smooth and apply some anti rust coating. You may not have as big as problem as me since your treads are not as big, the pinch weld just hit the edge of the tread on the tire. I guess it wouldnt be a jeep if there werent some type of mods done. Let me know how it turns out!!
post #5 of 6 Old 08-31-2010, 01:12 PM
VMF
2008 KK Liberty
that looks awesome ! share what you used! links included i might follow ur steps, just might go for diff rims
___________________________
2008 KK limited 4x4. Inferno Red
2009 JK Rubicon. Black
2004 UCF31. Black
2001 EM2. Inca pearl
2012 UD Limited. Royal Gray
VMF is offline
post #6 of 6 Old 10-08-2010, 10:49 AM
bigberto
2010 KK Liberty
Got mine done, yeah had to do the same pinch weld thing and stuff... but i love it!!!
see my listing.. http://www.jeepforum.com/forum/f292/...heels-1112686/
bigberto is offline
Wheels and Tires RB145 KK Liberty Forum 4 08-14-2010 11:40 AM
First time taking the 08 liberty off road Pics attached bigworm36 KK Liberty Forum 14 07-07-2010 10:06 PM
Want to see pics of after market Tires matt1u2 KK Liberty Forum 2 03-24-2010 05:47 PM
Looking for Stock Wheels and Tires erjennin KK Liberty Forum 3 03-13-2010 08:26 PM
