my kk died - JeepForum.com
post #1 of 11 Old 07-21-2013, 09:57 AM Thread Starter
carlosburitica
2010 KK Liberty
my kk died
yerterday morning went to start my kk, and boom dead, sounded like a dead battery to me (battery is maybe a year old, but who knows) took my other car, want to work and when i got back i tried to jump start the car and still nothing, some times you can see on the panel the word fuse, check engine light is on and flashes 10 times and stays on.
all you can hear is the tac, tac, tac, tac. but no sight of starter motor trying to turn....
i have 44k miles and extended warranty and i think i am going to call tomorrow to the dealer to come a pick it up.
any clues??????
carlosburitica is offline
post #2 of 11 Old 07-21-2013, 11:07 AM
khalilw
2011 KK Liberty
Don't jump it, try to start the KK with the other batery directly connected.
khalilw is offline
post #3 of 11 Old 07-21-2013, 11:56 AM Thread Starter
carlosburitica
2010 KK Liberty
didnt work.
reading alot in the forum seems to me that is the wireless control module. any how i will call the dealer to come a pick up the car.
post #4 of 11 Old 07-23-2013, 12:40 AM
WhiteRider
2008 KK Liberty
Any word from the dealer? ...Any ideas what-so-ever as to what may have caused it? ...Perhaps anything electronic that you had touched in the days leading up to the "death"...?
I was removing a marker signal bulb housing at one point to steal power for a headlight/LED mod. A "no brainer" mod really. I must have been a little rough with it or something, ...killed everything electronic and wouldn't turn over. Decided to not be cheap, do it properly and re-wired. With a little help from my girlfriend's Festiva (not too proud about that), gave it a jump and, ...Voila! Major worries gone.
WhiteRider from tha "Fresh Coast"
2008 White Liberty Ltd. - K&N 77 series intake - Airaid Throttle Body spacer - Sylvania Silverstar Ultra's with LED mod - Warn Rear Recovery Hitch w/D-shackle - JBA UCA's and 3.5" Lift pkg. - 265/65/r18 BFG A/T Ko's
WhiteRider is offline
post #5 of 11 Old 07-25-2013, 09:17 AM Thread Starter
carlosburitica
2010 KK Liberty
got my car back....
and basically an 18.85 part became a 1162.95 job.......... had to put $100 from my pocket for deductible and $165 for a new battery, even when mine was good and they said it had to be done in order to warranty the repair (Bs.... big bs, had no choise)
take a look
post #6 of 11 Old 07-25-2013, 09:31 AM
tjkj2002
2002 KJ Liberty
Originally Posted by carlosburitica View Post
got my car back....
take a look
The purge valve did not cause a no start condition,that was what the MIL was on for and relates to the EVAP system which is just for emissions(fule vapor part of the emission system).The battery was your no start problem.I've seen brand new batteries,litterly less then 1 month old be bad.It happens and the batteries age has nothing to do with it being good or not when new vehicles are so senisitive to battery voltage.
tjkj2002 is offline
post #7 of 11 Old 07-25-2013, 10:21 AM Thread Starter
carlosburitica
2010 KK Liberty
i used a new battery from my ford escape that i purchased about 2 months ago and still did not start.
well. haw ever it was problem is solved. so far
post #8 of 11 Old 07-25-2013, 12:04 PM
Nafpu
2012 KK Liberty
None of it was warranty-type work?
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #9 of 11 Old 07-25-2013, 02:19 PM
RKK
2012 KK Liberty
I suspect bad grounding problem, some you tried with new battery. Or there is short some where, if this is the case your ford escape battery would have drained pretty fast.
RKK is offline
post #10 of 11 Old 07-26-2013, 08:48 AM Thread Starter
carlosburitica
2010 KK Liberty
only had to pay for the battery and have $100 deductible so my total bill was $265
post #11 of 11 Old 07-29-2013, 12:18 AM
Poncherello
2010 KK Liberty
Glad you got it fixed. I got to call the dealership again, just after having my Lib services for the "clock" and replacing the gas tank, now the blower control that direct air through the vents via, feet, window, and face will only direct air via window and feet and won't go to your face. I got 55K and another 5K my warranty is up
When you get knee-deep in a situation, floor it.
Poncherello is offline
