My door lock buttons randomly dont work. any help? - JeepForum.com
post #1 of 8 Old 09-20-2012, 06:27 PM Thread Starter
mickeymouse4348
So recently my door lock and unlock buttons (the ones on the driver door) stopped working and i would have to press it a few times to unlock the door and today it wouldnt work at all. the doors make a sound that sounds like if you press the lock button when the doors are already locked. i pressed the lock and unlock buttons a ton of times and i eventually just unlocked the doors manually. Any ideas what might be causing it or how to fix it?
mickeymouse4348 is offline
post #2 of 8 Old 09-20-2012, 07:04 PM
pshivers
2008 KK Liberty
I haven't torn apart my door yet myself, but it's doing the same thing. Pressing the unlock button will act as the lock button for the first 5 or so presses. Hasn't annoyed me enough yet, but I suspect a loose connection.
pshivers is offline
post #3 of 8 Old 09-20-2012, 08:53 PM
pshivers
2008 KK Liberty
I have the 4 volumes of dealer service manuals at home for the 2008 liberty. I will look up the wiring diagram, see how it works and get back with you.
pshivers is offline
post #4 of 8 Old 09-20-2012, 09:00 PM Thread Starter
mickeymouse4348
thank you!!!!
post #5 of 8 Old 09-21-2012, 07:25 AM
Eagle112199
2010 JK Wrangler
Try the TIPM. People say that goes bad and affects the door.
Jeep: It's a passion, not an obsession.
2010 JK Wrangler 2-Door
Soft Top
Eagle112199 is offline
post #6 of 8 Old 09-21-2012, 08:52 AM
pshivers
2008 KK Liberty
The wife took the jeep this morning to go for a run with some friends, so I haven't been able to get my hands on it yet. It looks like the whole switch assembly on the door just pops right out with a little prying. The book gives pins to test on the harness and the switch assembly. Unfortunately, as Eagle stated above, the Totally Integrated Power Module (TIPM) controls everything with relays and sensors to see if the doors are already locked and such. I'll have to get back to you later once I get my hands on it. The TIPM is located directly behind the battery.
pshivers is offline
post #7 of 8 Old 09-21-2012, 09:46 AM Thread Starter
mickeymouse4348
Thanks for your help
post #8 of 8 Old 09-21-2012, 09:58 AM
Eagle112199
2010 JK Wrangler
Yeah sorry I should of spelled it out more but I was on my phone doing it. I had the TIPM relpaced on while trying to solve the Chime problem KKs are known for. I have seen bunches of threads on this problem so look them up for more info. Good luck with it.
Soft Top
Servie Bulletin: 23-007-12 REV. A 2011-2012 Rear Door Lock Knobs Rattle JeepCares KK Liberty Forum 0 08-20-2012 02:05 PM
door lock actuator abeacon KK Liberty Forum 8 08-16-2012 10:20 AM
Driver's side door lock 2009 Liberty Jeff88 KK Liberty Forum 9 05-14-2012 06:48 PM
08 Liberty with uconnect buttons? Qwack KK Liberty Forum 12 07-05-2011 05:06 PM
All doors lock but the Drivers door slipperybrain KK Liberty Forum 2 02-01-2011 09:25 PM
